На форуме: 7
Вернуться   Форум VolSat > Спутниковые ресиверы > Enigma 2 Linux Based Receivers > AB IPBOX HD, Sezam HD > Enigma 2 для AB IPBOX 9xxxHD
Старый 04.07.2010, 19:01   #1
karea
Ресивер: Dreambox-800HDSE
Сказал(а) спасибо: 96
По умолчанию Enigma 2 от Tideglo AB IPBOX 9000HD, 900HD, 910HD, 91HD
Enigma 2 Nightly Build: 0.9.7 version
- enabled the possibility to use "openvpn --auth-user-pass FILE" command
- update openvpn to last stable release (it should solve problems on connection timeout)
- fixed the bug on recordings playback
- fixed RGB green color on Scart
- fixed AutoSwitch on Scart (so you can set if enable it or not in the enigma2 menu, this is not true
if the receiver is in standby mode: this means you will have always the signal trhought TV scart if something connected to the VCR Scart)
- fixed widesignal over the Scart connector
- fixed Scart's signals on cuberevo-250hd
- some other fixes on Scart to send the good signal to let other devices know that a signal is present
- fixed a bug on tuxtxt
- fixed the bug: channel name on front display when standby mode active in some casual cases
- fixed the bug: channel name on front display when standby mode active after that mediaplayer is used
- added fw_env.config in /etc/ directory, on flash you can edit it in the /var/etc/ directory (usefull for ippe's multibood editor plugin)
- fixed osd screenshot on webif
- /mnt/ directory is now writeable in flash version
- /media/ directory is now writeable in flash version
- little fixes for screen resolution mode changing
- fixed the reading for front panel display settings
- fixed the reading for time settings (let me know if you will find other bugs on getting correctly the time)
- fixed webremote on webinterface
- updated timezone list, more option available now same as the standard (if you find any kind of problem just report it)
- on flash version: now CleanupWizard should not ask you all the time to free the space left
- added possibility to update Date/Time automatically using the CuberevoVFD plugin (usefull for first enigma2 start: just press the yellow button
on the plugin screen and when you will exit from the plugin, the channel tuned will get updates for current date/time)
- fixed many e2 pathes to prevent from unwanted crashes
- optimized a bit the free space (now enigma2 should take less space than previous versions)
- Unicable should be better usable now
- added TuxboxPlugins plugin (wich should run old tuxbox *.so plugins: default directory where to place plugins is "/usr/lib/tuxbox/plugins/")
- first try fix for zd1211b and added also zd1211 wireless driver (insmod the zd1211.ko or zd1211b.ko module if you need to use it)
- first try fix for rt2870/rt3070 wireless driver (insmod the rt3070sta.ko module if you need to use it)
- update Enigma2 CVS to 03/07/2010
About wireless drivers: please report if they are working or not (i can't test them directly)
Enjoy it! Tideglo
http://enigma2.sifteam.eu/index.php?...Build%200.9.7/
Последний раз редактировалось karea; 04.07.2010 в 19:03.
Старый 01.08.2010, 18:25   #2
karea
PKT mod 9.7.1 Tideglo rev 0.9.7 for Cuberevo - Ipbox 9000\900\910\91HD
Changes compared to version 9.7:
- New skin Basic HD (default)
- InfoCenter now works as a plugin
- Added plugin BootPlus 2.1
- Added plugin PermanentClock
- Added plugin AutoResolution
- Thrown plugin MyTube
- New Graphical Multi EPG
- New Blue Panel POINT
- New Emu Manager 0.9.9
- New Mount Man 0.7.4
- New Skin options in the Setup
- Adjust the skins to the new changes POINT
- Slimming skins
- Optimization of libraries
- Update Picon
- Reorganization MENU
- Many other small fixes
Cм. http://e2.pkteam.pl/index.php?dir=IM...9.7.1_usb_sata
Старый 08.09.2010, 11:34   #3
karea
По умолчанию Enigma2 NightlyBuild 0.9.9/ Cuberevo Mini2 (3000HD-910HD)
release 0.9.9
- added cuberevo-100hd support
- updated enigma2 cvs
- first try of improving system stability
Enjoy it! Tideglo
Cнег на HD каналах продолжается!
http://enigma2.sifteam.eu/Enigma2%20...o-mini2.tar.gz
http://enigma2.sifteam.eu/Enigma2%20...2_flash.tar.gz
Последний раз редактировалось karea; 08.09.2010 в 12:49.
Старый 04.11.2010, 17:53   #4
karea
По умолчанию Enigma2 NightlyBuild 1.0.0
Enigma2 NightlyBuild 1.0.0 / Cuberevo Mini2 (3000HD-910HD)
release 1.0.0
- enabled movie-list menu also on 100hd, 200hd, 250hd (press PLAY button instead of FILE on other receivers)
- fixed some playback bugs
- updated crossepg patches (compatible with last crossepg version)
- fixed some CI-CAM compatibility
- first try to fix TimeZone bug (time should be always ok now, standby and running mode)
- unicable is now more customizable (check enigma2 configuration)
- synced enigma2 with 29/10/2010 cvs
Enjoy it! Tideglo
release_100_cuberevo-mini2.tar.gz
release_100_cuberevo-mini2_flash.tar.gz
Enigma2 NightlyBuild 1.0.0 / Cuberevo Mini (900HD)
release_100_cuberevo-mini.tar.gz
release_100_cuberevo-mini_flash.tar.gz
Enigma2 NightlyBuild 1.0.0 / Cuberevo (9000HD)
release_100_cuberevo.tar.gz
release_100_cuberevo_flash.tar.gz
Имиджи от nlb для AB IPBOX 9000HD, 9x0HD, 91HD Admin Image для AB IPBOX 9xxxHD 12 10.05.2016 06:37
Оригинальные имиджи от DGS для AB IPBOX 9000HD, 9x0HD, 91HD Admin Image для AB IPBOX 9xxxHD 12 20.10.2010 13:12
Enigma 2 от Sifteam для AB IPBOX 9000HD, 900HD, 910HD, 91HD Admin Enigma 2 для AB IPBOX 9xxxHD 6 08.09.2010 11:12
Имиджи UFM для AB IPBOX 9000HD, 9x0HD, 91HD Admin Image для AB IPBOX 9xxxHD 1 05.10.2009 09:05
Азбука ресиверов AB IPBox 9000HD / 900HD / 910HD / 91HD Admin FAQ AB IPBOX HD 14 11.06.2009 10:34
Текущее время: 04:34. Часовой пояс GMT +3.
