Тем: 4,588, Сообщений: 360,956, Пользователи: 159,909
На форуме: 45
Вернуться   Форум VolSat > Спутниковые ресиверы > Enigma 2 Linux Based Receivers > AB IPBOX HD, Sezam HD > Image для AB IPBOX 9xxxHD
Старый 04.12.2008, 16:27   #1
По умолчанию Оригинальные имиджи от DGS для AB IPBOX 9000HD, 9x0HD, 91HD
Обсуждать сдесь что-либо запрещается!
Обсуждения ведутся в этой теме!
Старый 26.01.2009, 10:29   #2
По умолчанию Оригинальные имиджи от dgs для AB IPBOX 9000HD, 900HD, 910HD, 91HD
AB IPBox 91HD = CubeRevo 250HD
софт от DGS
скачать
Старый 26.01.2009, 10:35   #3
По умолчанию оригинальные имиджи от dgs для 9000HD
DGS official release r8873
1. Add Jump forward/backward function on Video player, except MPEG 1 and MPEG 2 files which are not supported yet.
press once FF or REW button, the interval is 10 seconds.
press and hold FF or REW button, the interval will be increased exponentially. it depends on whole file size.
2. Add Scan option on Channel Scan Menu
When there is no channel list, all these options create with the same result.
- Default scan : scan keeping current FAV list, and new channels will be placed at end of the channel list.
- Smart scan : remove current channel list , and scan, and then update FAV list according to the new channel list.
- Reset scan: remove all of the current channels and FAV group, then scan with new channel data.
3. Add USB upgrade menu
- Main Menu -> Advanced Setup -> Software Upgrade -> USB Mode
it is useful for software upgrade with USB morory stick.
4. Fixed EPG contents Display
- inserted new line on the screen for EPG and extended EPG information as well
5. Fixed DVB subtitle - color table
6. Fixed OSD teletext - some old data not updated occassionally
7. Fixed wrong duration with the file after schedule recording with EPG
8. Fixed Local time auto update
- When the last channel time of the Satellite is different from the STB time within 10 minutes,
the STB time is automatically adjusted with the Satellite time during the STB booting.
9. Updated Polish language table.
10. Updated Web-interface
11. Fixed small bugs
known issues : sync with audio and subtitle
artefact with premiere HD channels from satellite and cable
no audio with such as Digifilm channel
adjust color table of DVB subtitle for some channels
скачать
Старый 26.01.2009, 10:45   #4
По умолчанию оригинальные имиджи от dgs для 910HD
Release r8873: ( 22/Jan/2009)
скачать
Старый 07.03.2009, 01:54   #5
По умолчанию 05.03.2009
DGS release r9047: ( 5/Mar/2009)
1. Added additional channel scan options for TV or Radio
2. Added repeat function in Video Player
3. Added navigation method for TTXT sub-channel
4. Display the summary when searching channel
5. Save the name of recorded file when user want to schedule in EPG
6. Fixed bug Toptext navigation with TTXT
7. Fixed bug which was CubeRevo always blocked when first boot After update
new software
8. Fixed bug which was CubeRevo-250HD and CubeRevo-mini were not updated
local timer after AC power off even with Automatic time setting
9. Fixed Alphacrypt German Language Encoding bug
10. Included some of the new plugins in CubeRevo SW version.
- Thanks as below developper for plugin.
They are arvy of Shoutcast, coOLOser and pacco of Favpip plug, kneubi of Bitrate plugin and mail,
dexter of Webepg and webepg_import, pippo9000 of epg9kdld, coOLOser of fps,
pong, sudoku, tetris, andd weather of Neumoteam.
11. Updated German language translated by Nilse
12. Removed subtitle language setting in Language Settings Menu
users control through subtitle option on RCU.
13. Modified pop up message 'Service is not available' disappears after 5~6
seconds automatically
14. Adjusted the position of Pillar box
15. Adjusted color table of DVB subtitle for some channels
Note.
1. Added Multi booting function
If you want to multi-boot, download usb_config.img in our homepage(www.dgstation.co.kr)
Then press number button on RCU which you want booting mode.
Multi-booting support as below. Official image is number 3.
1) boot from cdkroot
2) boot from USB with hdd
3) original images
4) boot from release
5) boot from USB without hdd
6) boot from SATA hdd
7) boot from flash
2. The Digifilm channel works in official CAM.
скачать
Старый 06.04.2009, 14:47   #6
По умолчанию DGStation/Abcom CubeRevo Series nlb svn9207 v1.31
WEBIF
login: root
password: relook
Prepared by : Dexter
Release date : April 4. 2009
Changes:
* updated - Using DGStation release SVN9207
* emu - added - Hypercam 1.1
* emu - added - replace.list config for german provider support
* webif - new carddriver change between dgstation and custom driver, if issues are found.
* skins - deepblue, grey and blue updated to r9207.
http://rapidshare.com/files/217373731/nlb9207-mini.zip
Старый 04.05.2009, 00:33   #7
По умолчанию r9341 from DGS
r9341 from DGS
Скачать
Старый 23.06.2009, 09:48   #8
По умолчанию Cuberevo Series 1.0.(r9580) version
Image version : r9580
DB version : r9274
Caution)
1. You??d better backup the channel list using PC Editor before downloading the new images.
2. If your STB ??db version?? is an older version, you should download the image with ??db.img?? like ??usb_kernel_root_db.img?? ??usb_nobbot.img??
If your STB ??db version?? is the same version, you can download the image without ??db.img?? like ??usb_kernel_root.img??.
3. If AC power is unstable or disconnected while image downloading, pictures may not appear on the screen properly. In that case, you should make USB download mode once more and perform downloading the image again.
4. Please read the README file carefully before you start downloading.
Cuberevo Link is http://dev.dgstation.co.kr/release/c...580.292050.zip
Cuberevo-7000HDPVR Link is http://dev.dgstation.co.kr/release/c...580.292154.zip
Cuberevo-Mini Link is http://dev.dgstation.co.kr/release/c...580.292143.zip
Cuberevo-3000HDPVR Link is http://dev.dgstation.co.kr/release/c...580.292137.zip
Cuberevo-2000HDPVR Link is http://dev.dgstation.co.kr/release/c...580.291907.zip
Cuberevo-250HD Link is http://dev.dgstation.co.kr/release/c...580.292250.zip
Cuberevo-200HD Link is http://dev.dgstation.co.kr/release/c...580.291908.zip
To get patch files related to GPL license, please click HERE
Старый 10.08.2009, 14:34   #9
По умолчанию Cuberevo Series 1.0.(r10336) version
Image version : r10336
DB version : r9274
Caution)
CubeRevo : http://dev.dgstation.co.kr/release/c...336.080126.zip
Cuberevo-Mini : http://dev.dgstation.co.kr/release/c...336.080129.zip
Cuberevo-3000HD : http://dev.dgstation.co.kr/release/c...336.080130.zip
Cuberevo-250HD : http://dev.dgstation.co.kr/release/c...336.080131.zip
Cuberevo-2000HD : http://dev.dgstation.co.kr/release/c...336.080131.zip
Cuberevo-7000HD : http://dev.dgstation.co.kr/release/c...336.080132.zip
Cuberevo-200HD: http://dev.dgstation.co.kr/release/c...336.080133.zip
Старый 31.08.2009, 14:29   #10
По умолчанию Cuberevo Series 1.0.(r10513) version
Image version : r10513
DB version : r9274
Caution)
1. You had better backup the channel list using PC Editor before downloading the new images.
2. If your STB db version is an older version, you should download the image with usb_db.img like usb_kernel_root_db.img usb_nobbot.img.
If your STB db version is the same version, you can download the image without db.img like usb_kernel_root.img.
CubeRevo
Cuberevo-Mini
Cuberevo-3000HD
Cuberevo-250HD
Cuberevo-200HD
Cuberevo-7000HD
Cuberevo-2000HD
Старый 01.08.2010, 17:34   #11
karea
Ресивер: Dreambox-800HDSE
Сказал(а) спасибо: 96
По умолчанию Новые прошивки Cuberevo Series 1.0. r13059 version
См. http://www.dgstation.co.kr/new/cs_so...tegory=&page=1
Image version : r13059
DB version : r11421
1.Improve and fix bugs in Media list menu
(1). Support *.mkv file format in Video player
Recommended MKV file resolution is under or equal 720p
But normal avi file supports up to 1080i
(2). Support previous/next track in music files
(3). Support Multiple files editing function
2. Add Blind scan function for sharp tuner
3. Support EPG data store in HDD for back up, if no HDD, same method with previous
4. Add Channel list option as display simple, 1 Row, 2 Row
5. Fix some of other bugs
Caution
Cuberevo : ftp://dev.dgstation.co.kr/pub/cubere...all_noboot.zip
Cuberevo-Mini : ftp://dev.dgstation.co.kr/pub/cubere...all_noboot.zip
Cuberevo-3000HD : ftp://dev.dgstation.co.kr/pub/cubere...all_noboot.zip
Cuberevo-250HD : ftp://dev.dgstation.co.kr/pub/cubere...all_noboot.zip
Cuberevo-7000HD : ftp://dev.dgstation.co.kr/pub/cubere...all_noboot.zip
Cuberevo-2000HD : ftp://dev.dgstation.co.kr/pub/cubere...all_noboot.zip
Cuberevo-200HD : ftp://dev.dgstation.co.kr/pub/cubere...all_noboot.zip
If you want multiboot function, download attached multiboot-XXXX.img.Then press number button which you want on RCU when start up from shutdown.Multiboot function supports as below style.
# 1 boot with CDKroot(NFS)
# 2 boot from USB memory stick, with internal HDD
# 3 original images as current flash memory
# 4 boot with NFS
# 5 boot from USB memory stick, but without internal HDD
# 6 boot from internal SATA HDD
# 7 boot from flash memory for another image
Default value : no.3
u-boot is attached as below.
Последний раз редактировалось karea; 01.08.2010 в 17:51.
Старый 11.08.2010, 06:57   #12
karea
По умолчанию SifTeam-0.3.99-r13078 for Ipbox 910 USB version
С прозрачными скинами.
Устанавливается также как Enigma 2, запускается из под прошивки PGI-0.7.2a во флеше ресивера, необходимо изменить мультибут командой
Код:
fw_setenv menu_7 'front_puts "DGS-SDB1";setenv bootusb "run bootargsusb;usb reset;ext2load usb 0:1 a5ff0000 boot/uImage;bootm a5ff0000";setenv bootargsusb "setenv bootargs console=ttyAS1,115200 panic=3 root=/dev/sdb1 rw rootdelay=10 bigphysarea=1500 quiet";setenv bootcmd "run bootusb";saveenv;boot'
Запускается по кнопке [7].
Oscam+MGCamd for Ipbox Sif Image в приложении.
P.S. При переходе с PGI на DGS и обратно теряет базу каналов.
Тип файла: zip IPBOX9000HD_2.3_OSCAM_MGCAMD.zip 666.0 Кб 26
Последний раз редактировалось karea; 11.08.2010 в 07:11.
Старый 20.10.2010, 13:12   #13
karea
По умолчанию ALL-ADDONS for DGS
ALL-ADDONS for DGS
ADDONS
Имиджи от nlb для AB IPBOX 9000HD, 9x0HD, 91HD Admin Image для AB IPBOX 9xxxHD 12 10.05.2016 06:37
Имиджи от SifTeam для AB IPBOX 9000HD, 9x0HD, 91HD Admin Image для AB IPBOX 9xxxHD 18 28.08.2012 23:27
Имиджи UFM для AB IPBOX 9000HD, 9x0HD, 91HD Admin Image для AB IPBOX 9xxxHD 1 05.10.2009 09:05
Оригинальные имиджи от AB для AB IPBOX 9000HD, 9x0HD, 91HD Admin Image для AB IPBOX 9xxxHD 8 11.06.2009 10:44
Азбука ресиверов AB IPBox 9000HD / 900HD / 910HD / 91HD Admin FAQ AB IPBOX HD 14 11.06.2009 10:34
Текущее время: 22:22. Часовой пояс GMT +3.
