Тем: 4,562, Сообщений: 362,223, Пользователи: 160,661
На форуме: 11
Вернуться   Форум VolSat > Спутниковые ресиверы > Enigma 2 Linux Based Receivers > AB IPBOX HD, Sezam HD > Image для AB IPBOX 9xxxHD
Старый 04.12.2008, 16:18   #1
Сказал(а) спасибо: 2,205
По умолчанию Оригинальные имиджи от AB для AB IPBOX 9000HD, 9x0HD, 91HD
Обсуждать сдесь что-либо запрещается!
Обсуждения ведутся в этой теме!
Старый 10.03.2009, 17:16   #2
По умолчанию оригинальные имиджи от ab для 910hd
AB (DGS based)release r9057: ( 10/Mar/2009)
1. Fixed Astra 23,5E, TP 11876, 11992 PANIC problen
2. Added additional channel scan options for TV or Radio
3. Added repeat function in Video Player
4. Added navigation method for TTXT sub-channel
5. Display the summary when searching channel
6. Save the name of recorded file when user want to schedule in EPG
7. Fixed bug Toptext navigation with TTXT
8. Fixed bug which was AB IPBox 91HD and 910HD were not updated
local timer after AC power off even with Automatic time setting
9. Fixed Alphacrypt German Language Encoding bug
10. Included some of the new plugins .
- Thanks as below developper for plugin.
They are arvy of Shoutcast, coOLOser and pacco of Favpip plug, kneubi of Bitrate plugin and mail,
dexter of Webepg and webepg_import, pippo9000 of epg9kdld, coOLOser of fps,
pong, sudoku, tetris, andd weather of Neumoteam.
11. Updated German language translated by Nilse
12. Removed subtitle language setting in Language Settings Menu
users control through subtitle option on RCU.(this function will be back in next versions)
13. Modified pop up message 'Service is not available' disappears after 5~6
seconds automatically
14. Adjusted the position of Pillar box
15. Adjusted color table of DVB subtitle for some channels
Note.
Images marked as "DRE" are especialy for DRE CAM modules use. If you donґt have this CAM, donґt use "DRE" version !
1. Added Multi booting function
If you want to multi-boot, download usb_config.img in our homepage(www.dgstation.co.kr)
Then press number button on RCU which you want booting mode.
Multi-booting support as below. Official image is number 3.
1) boot from cdkroot
2) boot from USB with hdd
3) original images
4) boot from release
5) boot from USB without hdd
6) boot from SATA hdd
7) boot from flash
2. The Digifilm channel works in official CAM.
3. This image include sci.ko and smart_core.ko
known issues :
sync with audio and subtitle
artefact with premiere HD channels from satellite and cable
USALS doesnґt initialized correctly after box crashed
http://download.abcom.sk
аддон с эмулятором для 910
http://www.satupdate.net/
Порядок установки аддона:
Устанавливаете имидж 9057
Разархивируете аддон из архива.
Переименовываете его в usb_update.img
Устанавливаете с флешки также как и обыкновенный имидж.
Старый 10.03.2009, 17:22   #3
Note.
3) original images
7) boot from flash
known issues :
аддон с эмулятором для 900
Старый 10.03.2009, 17:23   #4
По умолчанию оригинальные имиджи от ab для 9000hd
Note.
3) original images
7) boot from flash
known issues :
аддон с эмулятором для 9000
Старый 02.04.2009, 21:07   #5
leopold75
Аватар для leopold75
leopold75 пока неопределено
Всем привет!
AB-Com зарелизили новые прошивки - 9023
Release Notes:
AB release r9203 for AB IPBox 9xxxHD series: ( 02/Apr/2009)
1. Added 4:3 zoom function on 16:9 TV system
2. Added Ukraine language on the menu
3. Added Display with channel numbers on front display instead of the non-Latin characters
4. Keep the current file system without automatic format even though the file system is ext2 or ext3.
5. Fixed File name bug of the main recording event on EPG Schedule Record
6. Fixed CSLink panic on ASTRA 23.5E 11876
7. Fixed Web interface bugs(no RCU image, 91HD didn't work Web interface, etc) and Update Web interface version
8. Fixed Display strange EPG time info on the banner
9. Fixed Subtitle sync.
10. Fixed Audio jerky on BadrC(26.E) 11938V
11. Fixed A/V Freeze of some HD & SD channels in Turksat, Eutelsat and so on.
12. Fixed Panic problem on ERT world and ERT Sat channels
13. Fixed no audio on Eurosport HD, and Sport HD of Eutelsat 36E TP 12111.
14. Improver stability with file playback and trick functions use
15. Add back menu item "Subtitle language" to language setup menu
16. Updated Russian, Romanian and Slovak language.(Russian is translated by Andrei Nazarenko, thank you Andrei)
17. Updated Smartcard driver
18. Added Drag interval adjustment preciesely such as
10 sec, 30sec, 1min, 5min, 10min, 30min, 1hour in recorded files or timeshift
Adjustment:
1. menu(System Settings --> Drag Interval),
2. direct buttons only with "Recorded files" with Pg+/- on RCU.
Note.
1. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
Note2
1. Files AB_9000HD_r9203DRE_020409_usb_all_noboot.zip
supported only DRE Cam`s. If you don`t use Dre Cam module, don`t use this image version!!!!
Known issues(on going).
1. Artefact with Premiere HD channels from satellite or cable.
2. Channels with nonstandard characters in name , e.g. "+" show on display as channel number only. Will be fixed in next version.
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. You have to change the name of updated sw into "usb_update.img" when you upgrade the sw by the USB memory stick.
RCU - Remote Control Unit (пульт ДУ)
- Добавлена функция масштабирования 4:3 для телесистем формата 16:9
- В меню добавлен украинский язык
- Добавлено отображение номера канала на фронтальном дисплее в случае отсутствия латиницы в имени канала
- Сохранение текущей файловой системы без автоматического форматирования даже в том случае, если файловая система ext2 или ext3
- Исправлен баг с именем файла в случае записи, установленной по планировщику c EPG
- Исправлен баг - креш ядра системы во время сканнирования каналов на спутнике ASTRA, орбитальная позиция 23.5E, частота 11876
- Исправлены ряд багов веб-интерфейса в 91HD, таких как отсутствие изображения пульта управления,
неработающий веб-интерфейс и др. баги, а также произведено обновление версии веб-интерфейса
- Исправлено отображение странного ЕПГ-времени на информационном баннере
- Исправлен баг с синхронизацией субтитров
- Исправлен баг с "толчкообразным звуком" на спутнике BadrC, орбитальная позиция 26.E, 11938V
- Исправлен баг с зависанием звука и изображения на некоторых HD и SD каналах на Turksat, Eutelsat и др.
- Исправлен баг - креш ядра системы на каналах ERT world and ERT Sat
- Исправлен баг с отсутствием звука на каналах "Eurosport HD" и "Sport HD" на спутнике Eutelsat, 36E, транспондер 12111
- Улучшена стабильность во время проигрывания файлов и использовании "trick" функции
- Восстановлен пункт меню "Язык субтитров" в меню настройки и выбора языка
- Обновлены переводы на русский, румынский и словацкий языки
- Обновлен SmartCard драйвер
- Добавлена возможность точной установки интервала захвата при записи файлов или функции timeshift
10 sec, 30sec, 1min, 5min, 10min, 30min, 1 час
Как настроить:
1. Menu --> System Settings --> Drag Interval,
ПРИМЕЧАНИЯ.
1. Файловая система ext3 работает медленнее, чем ext2.
Если вы записываете 2 канала в HD-качестве с использованием ext3, могут быть проблемы и провалы в записи.
2.
ВАЖНО!!! Files AB_9000HD_r9203DRE_020409_usb_all_noboot.zip
предназначен для использования ТОЛЬКО с DRE Cam`s.
Если вы не используете DRE CAM модуль,
НЕ ИСПОЛЬЗУЙТЕ ЭТУ ВЕРСИЮ ПРОШИВКИ!
Существующие проблемы и известные баги:
1. Артефакты на Premiere HD каналах, со спутника или по кабелю.
2. Каналы с нестандартными символами в названии, например "+", отображаются на дисплее только как номер канала.
Это будет исправлено в следубщей версии.
ВНИМАНИЕ!
1. Мы настоятельно рекомендуем отформатировать ваш USB-флешку перед заливкой имиджа,
в противном случае, это может привести к сообщению "ER10".
2. Если обновление будет проводиться с флешки, нужно изменить имя файла прошивки на "usb_update.img" (без кавычек)
Скачиваем тут:
IPBox 9000 HD
AB release r9203 for AB IPBox 9000HD series: ( 02/Apr/2009)
Для остальных моделей (900, 910, 91) :
IPBox 900, 910, 91 - new firmware release
leopold75 вне форума   Ответить с цитированием
Старый 06.04.2009, 14:18   #6
По умолчанию AB_r9207_060409_usb_all_noboot
1. Add russian (cyrilic) translate to latin letters for front display (thanks for Janigor for your help) 2. Fixed : Channels with nonstandard characters in name , e.g. "+" show on display as channel number only. Note 1. Files "...r9207DRE.." supported only DRE Camґs . If you donґt use Dre Cam module, donґt use this image version !!!! Known issues(on going). 1. Artefact with Premiere HD channels from satellite or cable. Caution. 1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10". 2. You have to change the name of updated sw into "usb update.img" when you upgrade the sw by the USB memory stick.
Скачать для 9000HD
Скачать для 900HD
Скачать для 910HD
Скачать для 91HD
Старый 04.05.2009, 00:35   #7
По умолчанию r9341 from ABCOM
AB r9341 30.04.2009
Change log:
1. Added automatical services moving when PMT_PID is changed on channel.
2. Fixed Greek Teletext bug on ERT World Hotbird 13, tp 11642.
3. Fixed the bugs that doen't display TTXT on the specific page.
The 777page of TTXT on Hotbird 8 (13.0E) - 11919.00 V
4. Update trick speed in File play and live banner Original : X2, X3, X4, X5 and (X1/5), (X1/4), (X1/3), (X1/2)
Advanced : X2, X4, X8, X16 and (X1/16), (X1/8), (X1/4), (X1/2)
5. ADD Proportional jump function in File play If you press the numerical button in File play, it works as below.
- Press “1” : Jump to 10% of the recorded file
- Press “2” : Jump to 20% of the recorded file
- Press “3” : Jump to 30% of the recorded file …………
- Press “0” : Jump to beginning of the recorded file
6. Updated Russian language.
7. DB upgrade to version 9274. You can upload settings from older versions with PC Editor 1.2.50 and later.
Files "...r9341DRE.." supported only DRE Camґs . If you donґt use Dre Cam module, donґt use this image version !!!!
Скачать для 9000HD
Скачать для 900HD
Скачать для 910HD
Скачать для 91HD
Старый 11.06.2009, 10:44   #8
По умолчанию AB_HD_r9580_290509_usb_all_noboot
1. Add function displaying time always on Front panel
2. Add schedule recording title name on webif
3. Fixed video player panic when spdif is off
4. Fixed slow icon on TrickPlay and FilePlay
5. Mapping blue key as check key for 91HD in filebrowser
6. Change HDD clean process on hddinit script
7. Syunchronized sleep Mode as power control option
8. Adjust analog output level(advanced quality of Component, Composite and S-Video)
9. Update TP information Thor0.8W and Astra 19.2E
10. Fixed many small bugs Note. 1. Our Video player is related with CODEC, FPS(frame per second) and resolution. As you know, even if the Filename Extension is different each other, if the video codec is same each other, the two files work like same. If the video file's resolution is more than 720 X 576, it will works very well. So, we recommend below conditions. 1) resolution : 720 X 576. 2) FPS : 24, 25 and 30 fps. 3) Followin
Скачать для 9000HD
Скачать для 900HD
Скачать для 910HD
Скачать для 91HD
Имиджи от nlb для AB IPBOX 9000HD, 9x0HD, 91HD Admin Image для AB IPBOX 9xxxHD 12 10.05.2016 06:37
Имиджи от SifTeam для AB IPBOX 9000HD, 9x0HD, 91HD Admin Image для AB IPBOX 9xxxHD 18 28.08.2012 23:27
Оригинальные имиджи от DGS для AB IPBOX 9000HD, 9x0HD, 91HD Admin Image для AB IPBOX 9xxxHD 12 20.10.2010 13:12
Имиджи UFM для AB IPBOX 9000HD, 9x0HD, 91HD Admin Image для AB IPBOX 9xxxHD 1 05.10.2009 09:05
Азбука ресиверов AB IPBox 9000HD / 900HD / 910HD / 91HD Admin FAQ AB IPBOX HD 14 11.06.2009 10:34
Текущее время: 07:35. Часовой пояс GMT +3.
