На форуме: 3
Вернуться   Форум VolSat > Спутниковые ресиверы > Enigma 2 Linux Based Receivers > AB IPBOX HD, Sezam HD > Enigma 2 для AB IPBOX 9xxxHD
Старый 28.05.2009, 10:27   #1
По умолчанию Enigma 2 от Sifteam для AB IPBOX 9000HD, 900HD, 910HD, 91HD
release 0.4.0:
- fixed boot image that was not shown every time on every TV
- revert back to python 2.5, now you can use all enigma2 plugins for dreambox receivers wich do not have sources available and wich uses only python files
- fixed DHCP, now is working by network menu configuration
- added the option to enable DHCP also with nfs-server to load enigma2 (just change the kernel loading bootargs)
- fixed the overheading bug on date/time that caused to have always a wrong time/date
- fixed tuxtxt crashes and outputs management
- fixed the bug that causes Timezones outside of Europe not to work, always reverts back to GMT time. All times over 3+ GMT and under GMT did not work.
- spdif audio output on ipbox91hd/cuberevo250hd
- fixed subtitles on dreamtv-hd skin
- fixed aspect ratio: Pan&Scan and Pillar box settings reversed
- fixed menu selection options that were not selectable, like 8MHz bandwith selection, or many fec options
- fixed skin HD
- updated skin HD
- enabled ntfs as module
- patch for white subtitles (i don't know if this is usefull or not, but i thought it's better to have a
white subtitle with black background, just more viewable)
- fixed EPG button (now you can choose wich kind of epg list to view)
- fixed deep standby broken since 0.3.3 (do not forget to delete all wakeup timers from dgstation firmware, because if you forget it,
then the box will restart automatically!)
- added a Satellites configuration with all sat positions (if you think there's something missed you can still add yourself configuration files)
- added a Terrestrial configuration to support almost all Europe providers (inserted general europe voice,
obiously i can't add a provider for each one on the worl, so just update the file if you need a specific provider)
- fixed some other channels scan bugs
- fixed menu Network test on the "link connection" voice
- fixed positioner menu crashes
- MediaPlayer Bug with a gsod on NoneType error using subtitles
- fixed rotor using diseqc
- reboot of enigma2 now should works good
- completed the kernel version p0041 adaption
- improved a bit CI cams manager
- fixed many memory bugs that caused the player to crash (let me know if you find more bugs on playing multimedia files)
- ipkg support, as soon as sifteam will have a download for ipk files you will be able to download them from the browse plugin menu
- added by default the file /var/etc/rcS_user.sh that is called on boot, so if you want to add any kind of command to be executed on start
just put them in this file
- patch for North American satellites (let me know if you find any kind of bugs)
ATTENTION:
if you are a NA user, do not forget to change in the "/etc/init.d/rcS" file this value:
insmod $MODDIR/stmfb.ko display0=1280x720-32@50:12M:PAL:YUV:RGB;
into:
insmod $MODDIR/stmfb.ko display0=1280x720-32@60:12M:NTSC:YUV:RGB;
This is needed to let you see the boot image and to have a full working display on TV.
Ok that's all, i know there are some other bugs to be fixed, but i think there were a lot of improvement in this version and
i'm working to some new drivers so i think before using the new drivers we should test all these improvements and then see if something could be better or not
Скачать
Старый 28.05.2009, 10:32   #2
По умолчанию release 0.4.2
ENIGMA 2 for all DGStation products:
- cuberevo-mini-fta (cuberevo-200hd)
- cuberevo-250hd (ipbox-91hd)
- cuberevo-mini (ipbox-900hd)
- cuberevo-mini2 (ipbox-910hd, cuberevo-3000hd, madtek-3000hd)
- cuberevo-2000hd
- cuberevo-9500hd (cuberevo-7000hd)
- cuberevo (ipbox-9000hd rel1 and rel2)
First boot take a little bit much more than a normal boot, so wait until you can see the bandeau bar (the one with infos on current channel) on the tv screen.
HISTORY:
release 0.4.2:
- fixed the diseqc bug, one for all, on the ipbox-91hd/cuberevo-250hd, cuberevo-200hd and all models wich uses the sharp tuner
release 0.4.1:
- fixed a bug on setting ip and dhcp on particular cases where dhcp server is off
Скачать
Старый 23.06.2009, 08:48   #3
По умолчанию Enigma2 sifteam 0.5.0 for HD boxes released
- cuberevo-2000hd
HISTORY:
release 0.5.0:
- fixed a bug on rebooting the system
- better CI cams handling
- support for upper and lower CI slots on the current live tuner, no more needs to put the cam only on the upper one
- added new dvdplayer
- support for timeshift
- fixed alpha blending colour on images
- updated e2 cvs to 30/05/2009
- fixed fstab auto mounting for hdd
- vsftpd log on file disabled by default
- fixed a bit keymap for 250hd/200hd, audio subtitles now is mapped
- added autoload of epg (using myepg now the file will be loaded automatically at enigma2 restarts)
- some fixes on mediaplayer for some multimedia files
- many fixes all around for better stability, now i think most part of drivers are done
- updated arabic language
I know there are still some bugs that sometimes break our balls too much, but i'm trying to solve all, just wait and hope
the funniest thing is finding those bugs
I would like to thank all people around Enigma2 for cuberevo, many teams are making really great stuff, i like how cuberevo
community is going on, i think this is the spirit our box should be!
I would like also to thank people making really great plugins, we will win all together!
See you on next release.
Скачать
Старый 18.08.2009, 09:17   #4
По умолчанию Sifteam Enigma2 Release 0.5.5
release 0.5.5
Ok from this release you will get a nightly build image. (this means i will not support stupid options like: panels, plugins and so on)
Soon a sifteam image will be out with panel and many options enabled.
I choose this way because i want that cuberevo community increase more! Many teams are involved in E2 now, so
each one can do his choice, and sifteam images will be out with another image (obviously based on the same Nightly build image version)
I will publish also how to build your own flash image, so every team can do it.
- new bootlogo (thanks arken)
- added bulgarian language
- added autofs
- added openvpn
- added openssl library
- added 576i to AutoResolution plugin
- added ftpput
- added ftpget
- added netstat
- "fixed" signal level on tuners
- teletext exit with "exit" button on remote
- fixed aspect on screen when exiting from teletext. If watching 16:9 format, it is shrinked, so looks like 16:6 or something
- fixed positioner setup
- fixed teletext subtitles
- remapped few buttons
- fix for DVB subtitles wich were not shown on some skins
- fixed bootlogo view on SD television
- fix the issue with stopping playback while it is paused
- incorporated the new web interface version (04/06/2009)
- fixed fast forward for MP3 in MediaPlayer
- enabled forwarding the second transport stream to the decoder
- fix avi 23.976fps/24.976fps/29.976fps
- avi: fix audio track selection early support for redirecting in http streaming
- added .rec extension file support
- CI cam drivers handling should now be better
- lot of fixes on PicturePlayer
- lot of fixes on MediaPlayer
- modified epgCache load to allow the load on e2 starts (now crossEpg works perfectly)
- added estonian language
- allowed to record/stream multiple channels from the same transponder (FTA only)
- There were a bug when a freeze happen on HD and SD channels, that bug showed you a full green pixel screen or an image repeating loop,
well this is bug was really hard to find for me and i'm not sure i've found all the cases when it happens, so... let me know if it happens again.
Попытка исправить рассыпания или так называемый "песок", автор не уве6рен что поправил все, но что-то уже сделано
Many people asked me to add smart card drivers made by pacco, but i've not did them, so i will not add them like part of my images.
They can be added manually by everyone and each team made the possibilty to download and install them, so i will not add them until
i will make my own version (wich i don't know when and how it will be ready, you can use the pacco's version wich is good enought)
Enjoy it! Tideglo
IPBOX 9000
IPBOX 900
IPBOX 910
IPBOX 91
Старый 02.12.2009, 21:32   #5
Armer
Armer пока неопределено
По умолчанию ENIGMA 2 for all DGStation products
- cuberevo-2000hd
Coder: Tideglo
HISTORY:
release 0.7.0
- fixed mute volume on channel change
- mute over SPDIF is now working
- added mp4 runtime detection
- added http mp4 streaming
- added m2ts file
- added stty
- added netstat
- added traceroute
- added grab for GUI screenshots (it does not work with live-tv screenshots)
- fixed many bugs on video drivers (don't remember all because most of drivers code were completly reviewed)
- applied better quality on video drivers (IMHO now on sd channels is really better than before)
- fixed many bugs on audio drivers (most of them on codec side)
- fixed (??) snr/agc value on tuners (especially in the sharp tuner)
- fixed bug on starting network at boot
- changed bootlogo with a new default
- reorganized general driver structures
- fixed subtitles *.srt and *.ssa when there is '.' char in the file name
- fixed time in the frontpanel (now should be always get the right value, with GMT offset, also at enigma2 boot)
- fixed a bug that causes DNS to be rewritten at reboot or at network restart when dhcp is activated on the router/net (if you have dhcp activated dns will be always given by dhcp server)
- fixed a bug that make dhcp always activated
- fixed record from standby
- fixed record from deep-standby
- fixed timer bug for record scheduled events
- fixed volume bug on web-interface
- fixed menu factory reset (thanks skaman)
- fixed panscan mode on almost all possible cases
- fixed audio volume on SCART wich was lower than HDMI
release 0.6.0
- fixed positioner setup using step diseqc command
- allowed 1080p 23,97 24 25 29,97 and 30Hz as display resolution
- fixed fastforward and seeking bug in mediaplayer
- added tuxtxt configuration file and a better readable font
- fixed fast forward in timeshift and playing recordings
- fixed slow-motion bug (micro-freezes on SD channels with 4:3 content)
- supported more HDMI tv using 576 output (edid bug should be fixed, report if some tv are not working during the wizard)
- supported MHW epg
- added:
/proc/stb/video/pal_h_start
/proc/stb/video/pal_h_end
/proc/stb/video/pal_v_start
/proc/stb/video/pal_v_end
- fixed a bug on volume value and changes
- fixed some memory leak bugs
- fixed a bug with dhcp
9000HD
200HD
250HD (91HD)
2000HD
9500HD(7000HD)
Mini 900HD
Mini2 (3000HD-910HD)
Armer вне форума   Ответить с цитированием
Старый 09.02.2010, 09:47   #6
По умолчанию Enigma 2 Nightly Build: 0.8.5 version
Originariamente inviata da ReadMe
HISTORY:
release 0.8.5
- fixed AC3 audio dropouts over SPDIF with downmix set to off on few HD channels (report if the bug still there on some channels)
- fixed the enable/disable 12v option in advanced enigma2 menu configuration
- fixed a high cpu usage bug on enigma2
- fixed pgup and pgdown buttons, now they are mapped to be used for channel changing
- added possibility to change bootlogo on flash images
- fixed a bug on few receivers that on 0.8.0 made them not working
- fixed a stability bug on all receivers
- fixed bug on the second tuner for scrambled channels
- added NTSC, 480i and 480p video modes support (i don't know if it works or not, i can't test it)
To people having problem with date/time:
since version 0.8.0 date/time is managed on the same way used on DGS firmwares, so if you at first are having a bad value
for date/time, just go into telnet console and type the command: date -s YYYY.MM.DD-hh:mm:ss
Replace YYYY with the year, MM with month, DD with day, hh with hour, mm with minute, ss with seconds.
After this type: cubefpctl --syncfptime
Now set your GMT offset on enigma2 configuration menu.
WARNING: using PIP with the second tuner on scrambled channel could make the tuner stops to work,
a full box restart is needed to make it working again.
I will try to fix this on next versions.
Enjoy it! Tideglo
USB and Flash versions here: http://enigma2.sifteam.eu/index.php?...Build%200.8.5/
Источник: http://forum.sifteam.eu/ipbox-hd-eni...tml#post489474
Старый 08.09.2010, 11:12   #7
karea
Ресивер: Dreambox-800HDSE
Сказал(а) спасибо: 96
karea очень-очень хороший человекkarea очень-очень хороший человекkarea очень-очень хороший человекkarea очень-очень хороший человекkarea очень-очень хороший человек
По умолчанию Neutrino HD Nightly Build: 0.4.0 version
- added cuberevo-100hd support
- many bug fixes on neutrino GUI system (some sporadic crashes)
- improved webif
- sync drivers with enigma2's
http://enigma2.sifteam.eu/index.php?...Build%200.4.0/
karea вне форума   Ответить с цитированием
Имиджи от SifTeam для AB IPBOX 9000HD, 9x0HD, 91HD Admin Image для AB IPBOX 9xxxHD 18 28.08.2012 23:27
Обсуждение Enigma 2 от Sifteam для AB IPBOX HD Admin Enigma 2 для AB IPBOX 9xxxHD 13 11.11.2010 10:25
Enigma 2 от Tideglo AB IPBOX 9000HD, 900HD, 910HD, 91HD karea Enigma 2 для AB IPBOX 9xxxHD 3 04.11.2010 17:53
Имиджи UFM для AB IPBOX 9000HD, 9x0HD, 91HD Admin Image для AB IPBOX 9xxxHD 1 05.10.2009 09:05
Азбука ресиверов AB IPBox 9000HD / 900HD / 910HD / 91HD Admin FAQ AB IPBOX HD 14 11.06.2009 10:34
Текущее время: 04:06. Часовой пояс GMT +3.
