На форуме: 37
Вернуться   Форум VolSat > Электронный мир > GPS навигация > Навигационное ПО и Карты > Garmin
Garmin Система автомобильной навигации.
Старый 01.03.2010, 13:50   #1
По умолчанию ПО для навигаторов Garmin
USB Drivers software version 2.3 as of December 1, 2009
Notes:
This setup will install / pre-load all Garmin USB Drivers on your system and upgrade older versions if found.
These drivers are designed for use with those GPS units that support USB transfer of data to/from the PC - not to include the iQue. This setup also includes the drivers for the USB Data Card Programmer.
This setup combines the initial install and updates for both the USB GPS drivers and the USB Data Card Programmer drivers.
Garmin GPS USB Drivers support Windows XP 64-bit, Vista 64-bit, and Windows 7 64-bit.
Garmin USB Data Card Programmer drivers do not support 64-bit operating systems at this time.
Garmin GPS USB Drivers have passed the Microsoft Logo Certification testing (Winqual) for all OS's up to and including Windows 7 x64
Скачать (3.19 MB)
Garmin Mobile® XT
Part Number: 010-10844-00
Unit Software:
Garmin Mobile XT for Palm Ver. 5.00.10p as of Sep 23, 2008 Download
Garmin Mobile XT for Palm (for older devices) Ver. 4.10.30p as of Nov 14, 2007 Download
Garmin Mobile XT for Symbian S60 2nd Edition Ver. 4.20.00 as of Jun 13, 2008 Download
Garmin Mobile XT for Symbian S60 3rd Edition Ver. 5.00.50 as of Apr 15, 2009 Download
Garmin Mobile XT for Symbian UIQ3.0 Ver. 5.00.20 as of Nov 26, 2008 Download
Garmin Mobile XT for Windows Mobile Ver. 5.00.20w as of Sep 25, 2008 Download
Garmin Mobile XT for Windows Mobile (for older devices) Ver. 4.10.40w as of Oct 12, 2007 Download
Additional Software:
Garmin Mobile XT Free Basemap Ver. 4.xx.xx as of Apr 19, 2007 Download
Garmin Mobile XT Support Files Ver. 4.xx.xx as of Jul 11, 2007 Download
Garmin Mobile XT for Windows CE 5.0:
Порядок установки:
1) Заливаем - Garmin_wince_5.00.10w_4pna.com.rar
2) Поверху GarminMobileXTforWindowsCE_50020w_only_WM_dir.rar
3) Дальше опять поверху измененые скрипты запуска - 3_Garmin.zip (в аттаче)
Garmin Mobile XT for Windows CE 6.0 (Скачать):
Установка:
1) Копируем папку MobileNavigator на вутренний флеш. Старую при этом переименовываем во что то другое, либо удаляем.
2) Папку Garmin можно размещать как на внутреннем флеш диске так и на SD карте.
3) Если размещаем на внутреннем флеше: То в папке MobileNavigator Переименовываем файл MobileNavigator_Resident.mscr в MobileNavigator.mscr
4) Если размещаем на SD карте: То в папке MobileNavigator Переименовываем файл MobileNavigator_SDMMC.mscr в MobileNavigator.mscr
5) Кладем карты в папку Garmin и запускаем.
В случае если вы разместили папку garmin во внутренней памяти, карты можно держать на SD носителе отдельно от программы.
Для этого просто создайте папку Garmin на SD носителе, и положите тужа ваши карты. При этом часть карт может лежать на внутреннем
флеше в папке Garmin, а часть на SD карточке в папке Garmin. Имена файлов с картами могут совпадать.
Если у вас по какой то причине Garmin не видит GPS в приборе - играйтесь с настройками COM порта в файле MobileNavigator.mscr
Править нужно следующую область:
setcominfo("com1:", 500,57600,"none",8,1,"none")
str = readfile( "com1:", 100 )
соответственно com1 меняйте на ваш, и скорость 57600 на вашу(например 9600)
данная сборка полностью проверена на jj-connect 2100WIDE с windows CE6
но должна работать на любом windows CE6 после внесения изменений в скрипты запуска
WebUpdater
WebUpdater For Legacy Windows Operating Systems (Pre Windows 2000), Ver. 2.4.0, as of Dec 20, 2006, Download
WebUpdater For Mac, Ver. 2.0.6, as of Apr 23, 2009, Download
WebUpdater for Windows, Ver. 2.4.2, as of Apr 22, 2009, Download
Тип файла: zip 3_Garmin.zip 77.2 Кб 36
Обсуждение Garmin vitj1970 Garmin 18 04.06.2014 17:47
Карты для навигаторов Garmin Admin Garmin 6 01.05.2013 09:09
Garmin Vista H Яныч Garmin 0 14.01.2012 10:37
Реанимация навигаторов Garmin sergeua Garmin 0 18.06.2011 10:29
FAQ по навигаторам и ПО от Garmin Admin Garmin 9 03.03.2010 15:58
Текущее время: 14:44. Часовой пояс GMT +3.
