На форуме: 7
Вернуться   Форум VolSat > Спутниковые ресиверы > Enigma 2 Linux Based Receivers > AB IPBOX HD, Sezam HD > Enigma 2 для AB IPBOX 9xxxHD
Старый 15.01.2010, 12:14   #1
По умолчанию AAF Wintertime Image IPBOX 9xxx HD
Image info
GIT Enigma2 AAF Winter Image (Image 15) Changelog:
Changelog since the last public release:
Team Ducktales (only IP-Box):
+ gotosleep changed as fp_control
+ MP3 Playback more stable
+ DTS Fix
+ Kernel optimisation
AAF Panel 7.9
MediaCenter
AAF
+ AAF Panel 7.9 (added VideoTune | several fixes and updates)
+ Volume Adjust (menu -> settings -> VolumeAdjust)
+ Cleanup Wizard (menu -> settings -> system ->...)
+ Crashlog Wizard (menu -> settings -> system ->...)
+ MediaCenter (IMDb Support | new Videplayer Filelist | WeatherPlugin | WebRadioFS)
+ miniuboot r1.3 update (for lzma compressed kernel, better compression and a littel more speed)
+ repairmodus (when error or bootloop)
+ usbspeed (test usb storage speed)
+ mixed lzma/zlib compression for /var (better compression and a little more speed)
+ usb-storage.usbwait123 kernel parameter (setting the boot sequence)
+ ntfs read/write support (you can activate this in aaf panel)
+ much fixes in samba server
+ only boot E2 on error (you can activate this in aaf panel)
+ new onlineflash tool (with verify and tv output)
+ new system layout (for more /var free)
+ partition load for problem storages (you can activate this in aaf panel)
+ some fixes in ramswap
+ wget, fsck, mkfs (percentage display on vfd and tv)
+ much other fixes...
Known problems:
- Sometimes after switching sound dropouts
(switching manually the channel or the sound helps)
- Timebug: you need a working Internet connection.
Rebootvideo
Shutdown Video
Thanks go to the sh4-receiver-developer for the amazing orig. Image and all that have helped to create and test it.
Your AAF Team
AAF Wintertime Image 9000 Flash
AAF Wintertime Image 9000 USB
AAF Wintertime Image 910 Flash
AAF Wintertime Image 910 USB
AAF Wintertime Image 900 Flash
AAF Wintertime Image 900 USB
AAF Wintertime Image 91 Flash
AAF Wintertime Image 91 USB
Старый 13.05.2010, 22:54   #2
roger5000
Ресивер: dreambox500hd
roger5000 пока неопределено
По умолчанию AAF The Spirit of Spring для IPBox 9000/910/900/91
So könnte das Image online gehen...
Änderungen zum Osterimage
z.B. Atevio 7000
M3321
+ PowerLED Helligkeitsregelung über VFD-Brightness regelbar
+ PowerLED im Softstandby aus
+ Kartenleser über SoftCam Panel aktivierbar (config unten S02 oben HD+)
+ Unterstützung für Vorschaubilder bei IPKs (Erweiterungen, Pluginbrowser)
+ Erweiterte EPG Einstellungen im AAF Panel
+ Unterstützung für Entschlüsselung mit 2. Tuner
+ MC Audio-/Videoplayer Filelistsortierung
+ MC Audioplayer mit aktuellem Titel im Screensaver
+ Python Update für Dateien über 2GB
+ Erweiterte Kindersicherung
+ Aufnahme Splitting im AAF Panel einstellbar
+ Ftp Server Erlauben von FXP/SSL Direkt Verbindungen
+ FtpFs Erlauben von SSL Verbindungen zum glftpd mit Proxy
GIT949
+ fix avi/fastforward memoryleak in libeplayer2
+ tuxtext fix
+ srt Untertitelerkennung verbessert
+ Aufnahme-Datei-Splitting
+ Möglichkeit mehrere Sender auf unterschiedlichen Transpondern gleichzeitig zu entschlüsseln
+ SHM Unterstützung
+ Unicable (Einkabel) Support aktiviert
+ Pufferspeicher für Streamproxy erhöht
+ SlowMotion
+ schneller Rücklauf
Флеш-версії:
http://rapidshare.com/files/38671990..._FLASH.7z.html
http://rapidshare.com/files/38672170..._FLASH.7z.html
http://rapidshare.com/files/38672356..._FLASH.7z.html
http://rapidshare.com/files/38672481..._FLASH.7z.html
roger5000 вне форума   Ответить с цитированием
Старый 10.06.2010, 06:49   #3
karea
Ресивер: Dreambox-800HDSE
Сказал(а) спасибо: 96
По умолчанию AAF WM-Image2010
AAF WM-Image2010
Boat image Kasimi
Amendments to the Spirit of Spring Image:
GIT rev1057
+ Fix freesat EPG
+ Stream Proxy improved
+ Fix kernel STM22
+ Based now to 95% from the Git
+ Szap Kernel
Git + Player2
+ Enigma2 06/2010
+ Only tuner, front panel and driver Tideglo CI 0.96
- Optimization is still in beta
AAF M3465
+ Szap (TV screen during the boot process already in under 30 seconds is possible)
+ Szaplong for virtually seamless transition into E2
+ Progress bar during boot (optional)
+ Fixed text button in MC
+ FullHD icon in the info bar at 1080i HD Ready with 720p channels
szap Info:
szap can be found at
-> Menu -> AAF Panel -> Settings -> Config szap
- Szap - Yes
activate
szaplong:
is an additional function of the selected channel with the E2 in szap channel synchronized so that a virtually seamless transition.
szap_frontend:
0, use Tuner1
Using a Tuner2
Thanks to Team Ducktales and all that in SH4 Duckbox project
at great base image involved. And of course, all this
Image will allow and have been tested.
910 HD Full USB
910 HD USB
Старый 04.07.2010, 16:12   #4
karea
AAF WM Image V2
neu aus aktuellen Anlass
Serverwechsel....
Änderungen zum WM Image:
GIT rev1093
+ Fix: Perform configured action at end of playback
+ fp_control bugfix und Codeoptimierung
AAF M3526
+ Fix checknet (Internettest für IPK Download)
+ Online Update fix
+ AAF Panel GS fix
+ Fan Control in standby thx Black [ufs922]
+ Tuner Treiber für neue Boxen [ufs922]
+ szap Sendererkennung Verbessert
+ szap EMU Unterstützung (Oscam/Vizcam)
+ szap Spinner fix
+ szap channel.list update
Bekannte Probleme:
- Probleme mit Timer-/Sofortaufnahmen auf Sky Cinema HD bei entschlüsselung über CI-Modul
- ARD/ZDF HD gleichzeitig aufnehmen kann zu Dauerspinner führen
Danke an Team Ducktales sowie allen, die im Duckbox SH4 Projekt
am tollen Basisimage mitwirken. Und natürlich an alle, die dieses
Image ermoeglicht und getestet haben.
Euer AAF Team
Wird wichtig für das Flashimage
USB und Full USB wird es eine tar.gz oder IPK geben...
damit könnt ihr Updaten...
bis die V2 auch hier verfügbar ist.
Im Anhang als Soforthilfe die tar.gz über ADDON Manger installieren lassen.
Nur für USB Images...
Для всех моделей http://www.aaf-board.com/wbb2/database.php
Старый 12.08.2010, 08:52   #5
karea
По умолчанию AAF Hot Summer Image
Changelog zum Hot Summer Image
Git 1131
+ fix Tuxtxt auf 2. Tuner
+ Installer Update (TF7700)
+ fix remote control and network problems (Atevio700)
+ Fixed Computer Icon in VFD Driver (TF7700)
AAF M3761
+ Erstes AAF Image für Kathrein UFS-912
+ Update PTS Plugin
+ Workaround Modules for ARD/ZDF HD Bug (TF7700) -> Thanks TDT
+ VFD Optimierungen (TF7700)
+ MC kleinere Fixes
+ restoring IPK Info for emus, config and SwapIPKs
+ CI Modul Workaround (UFS910, IP-Box)
+ HDMI and Scart Output @ 576i
+ Update AddOnManager
+ Senderliste aktualisiert
Bekannte Fehler
- mit den neueren Tunern eventuell Probleme
- szap (ab und zu Probleme)
Euer AAF Team
Download in der Database
Старый 06.09.2010, 19:47   #6
karea
По умолчанию AAF Hot Summer-V2 IP Box 910 Supportthread
AAF Hot Summer-V2 IP Box 910 Flash, USB. Full USB
Image Info
AAF Enigma2 Hot Summer Image V2(Image 23) Changelog:
SH4 Duckbox Projekt rev1172:
+ [libeplayer2] mkv update AAC_HEADER
+ fix VFD Icon Anzeige (Atevio)
+ sporadische Hänger am Ende von Aufnahmen gefixt
+ jfsutils (Atevio / Topfield)
+ Mute Icon (Atevio 7000)
AAF M3927:
+ Settings Back/Restore verbessert
+ DVD Player update / Fixes
+ AAF Panel Update / Fixes
+ Addon Manager Update
+ HDD mounting Fixes
+ kleinere start Optimierungen/fixes (Atevio)
+ Übersetzungsupdates
+ Boardviewer Update
+ Lautstärke beim start 100% gefixt
+ Lautstärkenanpassung für AC3 hinzugefügt
+ libeplayer2.so.0.0.0 behebt Probleme beim stoppen von mkvs
Bitte auch beachten:
- Nach Einrichten und Installieren das Nullmodem Kabel
am Receiver abziehen. Bei gestecktem Kabel
bootet der Receiver nur, wenn der PC an ist.
- Für Ton über HDMI in den A/V Einstellungen
SPDIF als Audio Source angeben
-AC3 Downmix ,,an'' stellen
Euer AAF Team
Download in: AAF IP Box Image
Последний раз редактировалось karea; 07.09.2010 в 10:40.
Старый 05.04.2011, 09:08   #7
karea
По умолчанию AAF MME V2 Supportthread IP91 IP900 IP910 IP9000
Änderungen zum Release MultiMedia Edition V1:
GIT 1852
- Neue Player Engine STM Havana Player 179
- Fix schnelles zurückspulen
- disable 2 unneeded processes
- [Libeplayer3] ogg / flac Playback
- [libeplayer3] some changes regarding playback flushing after playthrough
- Kartenleser Treiber
- [libeplayer3]decrease debug level due to some performance problems
- [libeplayer3] fix blocking at end of file
AAF M5873:
- enable libsmbclient
- VideoPlayer fix play same file after eof
- Tuner Treiber update
- Frontpanel Treiber Update
- Online Update Funktion
- kleinere fixes
- [mc] pictureplayer add mp3 support on slideshow
- Kanalliste in neuem look
Bekannte Fehler/Offene Punkte:
- Radiohintergrundbild geht im moment nicht
- webradiofs geht im moment nicht
Download
•IP Box 91 Flash http://www.aaf-digital.info/forum/do...do=file&id=493
•IP Box 91 USB http://www.aaf-digital.info/forum/do...do=file&id=464
•IP Box 91 FullUSB http://www.aaf-digital.info/forum/do...do=file&id=465
•IP Box 900 Flash http://www.aaf-digital.info/forum/do...do=file&id=467
•IP Box 900 USB http://www.aaf-digital.info/forum/do...do=file&id=468
•IP Box 900 FullUSB http://www.aaf-digital.info/forum/do...do=file&id=469
•IP Box 910 Flash http://www.aaf-digital.info/forum/do...do=file&id=471
•IP Box 910 USB http://www.aaf-digital.info/forum/do...do=file&id=472
•IP Box 910 FullUSB http://www.aaf-digital.info/forum/do...do=file&id=472
•IP Box 9000 Flash http://www.aaf-digital.info/forum/do...do=file&id=475
•IP Box 9000 USB http://www.aaf-digital.info/forum/do...do=file&id=476
•IP Box 9000 FullSUB http://www.aaf-digital.info/forum/do...do=file&id=477
Старый 06.06.2011, 08:17   #8
karea
AAF MediaCenter SpringV1 fix
SH4 Duckbox Projekt Git rev20xx:
+ [at7500] fix ird EXT (var) bug
+ [kernel] add optimized nodebug kernel cfgs at7500,ufs912, at700, at7000
+ [av700/0 - kernel] - activating SYSCTL
+ fix player CCFLAGSY position
+ [AV7000] use seperate register storage for each tuner
+ add ifo support
+ [libeplayer3] fix .srt subtitle
+ [libeplayer3] hack to save cpu usage with subtitles
+ [libeplayer3] fix fast reverse loops
+ [libeplayer3] fix xvid videostream in mp4
+ [libeplayer3] hopefully fixed zdf streaming problem without destroying playback of other h264 files
AAF M73xx:
+ add autofs support to Networkbrowser (cifs/nfs/ftp)
+ add smbfs to autofs
+ add upnpfs to autofs
+ add ntfsmount to autofs
+ add new bootpictures
+ add overclocking (at7500 & ufs912)
+ add AAF Wizard
+ add ntfs-3g to autofs
+ add wireless support (stm22 only)
+ change epg handling
+ change backup handling
+ change swapextensions handling
+ change mountsystem to autofs only
+ change bootlogo handling
+ optimize boottime
+ optimize onlineupdate
+ optimize tmpupdate
+ optimize swap
+ optimize Softcam Panel
+ move DVD player to Mediacenter my Videos
+ Fix WebRadioFS
+ Bouqueteditor in WebIF
+ [at7500] DVB-T Tuner (Test)
+ [ufs912] Chinch Audio fix
IP-Box910-Flash http://www.sat-universe.com/redirect...H_FIX.rar.html
IP-Box-910-USB http://www.sat-universe.com/redirect...B_FIX.rar.html
IP-Box-900-Flash http://www.sat-universe.com/redirect...H_FIX.rar.html
IP-Box-900-USB http://www.sat-universe.com/redirect...B_FIX.rar.html
IP-Box-900-USBFULL http://www.sat-universe.com/redirect...L_FIX.rar.html
IP-Box-9000-Flash http://www.sat-universe.com/redirect...H_FIX.rar.html
IP-Box-9000-USB-Update http://www.sat-universe.com/redirect...B_FIX.rar.html
IP-Box-9000-USBFULL http://www.sat-universe.com/redirect...L_FIX.rar.html
Оscaм для AB IPBOX HD karea EMU (Эмуляторы) для Enigma2 7 05.10.2015 21:56
как установить russian.locale на petze image andreyyyy Dbox2 11 16.07.2012 21:16
JTag на IpBox Admin JTag/Dump 0 20.09.2011 11:46
CCcam Emu для Ipbox HD karea EMU (Эмуляторы) для Enigma2 1 05.02.2011 23:45
IPBox 91HD jeta2008 AB IPBOX HD, Sezam HD 25 26.08.2010 21:36
Текущее время: 06:04. Часовой пояс GMT +3.
