Тем: 4,588, Сообщений: 361,024, Пользователи: 159,918
На форуме: 46
Вернуться   Форум VolSat > Спутниковые ресиверы > Enigma 2 Linux Based Receivers > Dreambox HD > Софт для DreamBox HD
Софт для DreamBox HD БЕЗ ОБСУЖДЕНИЯ!
Старый 25.09.2009, 21:59   #1
Misua
Радость Имиджи Newnigma для Drembox HD
Newnigma2 v2.8
http://depositfiles.com/files/50qyokmfd
  Ответить с цитированием
Старый 06.07.2010, 20:44   #2
По умолчанию newnigma2-v3.0.1-dm800-30-06-2010 clone
Newnigma2 team proudly presents:
Newnigma2 v3.0.1
Basics:
Enigma2 2.6: 30.06.2010
Enigma2 Plugins 2.6: 30.06.2010
Newnigma2 Plugins: 30.06.2010
DM 800 HD PVR
driver: 23.06.2010
secondstage: 76
DM 8000 HD PVR
driver: 23.06.2010
secondstage: 76
DM 500 HD
driver: 23.06.2010
secondstage: 79
Changelog:
update drivers 23.06.2010:
dm800/dm8000/dm500hd:
- PCR fixes (i.e. fixes the dm800 HDMI connection lost problem)
dm800
- revert some video output code changes (this fixes the MP4 playback problem introduced with 20100528 drivers)
update drivers 12.06.2010:
dm500hd:
- improved fan speed tacho readout a bit
- fixed broken error recovery
dm8000
- fixed swapped < > buttons on alternative remove control
update drivers 05.06.2010:
- fixes load averrage
- add support for three vtuner modes, small vtuner fixes (i.e. return codes for some ioctls)
dm8000/dm500hd:
- deinterlacer fix
dm500hd:
- add lost patch for IR problems since last update
- add error recovery for bootproblems
new plugin:
added Rytec epg plugin to our feeds. click here for more information
You can install this plugin easily via softwaremanager (this plugin is named enigma2-plugin-extensions-xmltvimport, bot Rytec epg) or
install it via console: opkg install enigma2-plugin-extensions-xmltvimport. Maybe you first have to make an "opkg update".
dvd:
some changes for dvdplaying made. dvd's should now work better then in 3.0.
new sambaserver 3.5.3:
this version works now fine with windows 7.
skins:
we have changed some things in our skins. now we have a variable cryptinfo for our skins. in most skins you can now choose
what you want: satposition, channelnumber, crypt-icons or crypt-text (maybe crypt-icons are not avaible for all skins). next event is only available in
newnigma2-HD/newnigma2.new/DMConcinnity-HD skins (we are working on it to put it in all skins).
You can select all this in our expert menu >> press blue button -> newnigma2 services -> system tools -> expert menu
(thx to dr_best for some hints and help)
fixes and updates (u have to install it, it is not in the image):
- kernelupdate for dreamdts (dtsdownmix)
- added merlin epg on feed
- added enigma2-plugin-extensions-2lang
- added enigma2-plugin-extensions-2sub
- added enigma2-plugin-extensions-2subconf
- added enigma2-plugin-extensions-cccaminfo (maybe not longer needed because we have a new crytpinfo)
multiboot:
no support for multiboot. Not planned, not wanted.
IMPORTANT
you can update from 3.0 to 3.0.1, no flashing needed. update via softwaremanager or console. Since the new kernel esata can cause some problems. it is better to use network attached storage or usb hdd's.
http://www.newnigma2.to/wbb2/jgs_db....oad_id=93&sid=
http://www.newnigma2.to/wbb2/jgs_db....oad_id=94&sid=
Старый 11.02.2011, 16:49   #3
balu122
Ресивер: driambox800
balu122 пока неопределено
Добрый день подскажите пожалуйста новечку можно поставить этот имидж на китайского дрима 800
balu122 вне форума   Ответить с цитированием
Старый 12.02.2011, 22:30   #4
olvik
Ресивер: DM800PVR
olvik пока неопределено
Сообщение от balu122 Посмотреть сообщение
Если внимательно прочитать первую строку поста
Адальше в тексте
secondstage: 76
olvik вне форума   Ответить с цитированием
Старый 24.01.2012, 00:29   #5
ivan1975
newnigma2-snapshot-dm800 http://www.satnet.ch/filedb/download.php?f=257908
Имиджи OoZooN для Drembox HD Misua Софт для DreamBox HD 1 24.01.2012 00:18
Имиджи MHD для Drembox HD levan Софт для DreamBox HD 12 24.06.2011 15:03
Имиджи Domica для Drembox HD Ligioner Софт для DreamBox HD 1 21.06.2011 11:58
Имиджи LS для Drembox HD Misua Софт для DreamBox HD 0 25.09.2009 22:09
Текущее время: 18:36. Часовой пояс GMT +3.
