Тем: 4,592, Сообщений: 361,173, Пользователи: 159,954
На форуме: 34
Вернуться   Форум VolSat > Спутниковые ресиверы > Спутниковые HDTV/MPEG4 Ресиверы > Другие HDTV ресиверы
Старый 15.09.2009, 20:44   #1
По умолчанию HD-BOX FS-9200 PVR Twin
Feature
Digital Satellite PVR & receiver
H.264 / MPEG4 - HD/SD , DVB-S2 Twin Tuner
Powerful compatibility through Embedded Linux OS
Time Shifting with various External Storage Devices
Recording & Playback with External Storage Devices ( e-SATA / USB 2.0 )
Recording and Time Shifting Simultaneously
Recording and Playback Simultaneously
Event Recording by EPG
Dual USB 2.0 Host Support (MP3 Player & JPEG Viewer)
Xvid file Playback Support
Ethernet port / Universal remote control unit
HDMI Video & Audio Output
External SATA connection supported (separate power is needed for Ext. HDD drive)
PIP(Picture-in-Picture) & Multi-picture Display
1W Stand-by Power Consumption
mgcamd -work
newcs -work
cccam - in progress, coming soon
enigma2 - in prgress, coming soon
Technical date
St7109 , Flash 32 Mb ,Sdram 192Mb , EEprom 128kb
FS-9200HD PVR
Tuner & Channel Decoder (Satellite)
Input Connector
Loop through out
Frequency Range
Input Impedance
Signal Level
LNB Power
22KHz Tone
DISEqC Control
Demodulation
Input Symbol Rate
FEC Decoder
F-type, IEC 169-24, Female
950MHz ~ 2150MHz
75?, unbalanced
-65 to -25dBm
13/18VDC, max.400mA
(222)KHz, (0.60.2)V
V1.0/1.2/USALS Compatible
QPSK / 8PSK
2 ~ 45 Ms/s(QPSK of DVB-S)
2 ~ 45 Ms/s(QPSK of DVB-S2)
2 ~ 37 Ms/s(8PSK of DVB-S2)
1/2, 2/3, 3/4, 5/6 and 7/8 with
Constraint Length K=7(DVB-S)
1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9 and 9/10 (DVB-S2)
MPEG Transport Stream A/V Decoding
Transport Stream
Profile Level
Input Rate
Video Formats
Video Resolution
Audio Decoding
Audio Mode
Sampling Rate H.264(MPEG-4 part 10, MPEG-4/AVC and H26L)
MPEG-II ISO/IEC 13818-2/11172-2
MPEG-4/AVC MP@L4, MPEG-II MP@HL
Max. 15Mbit/s
4:3 Letter Box, 4:3 PanScan, 16 : 9
720 x 576i, 720 x 576p, 720 x 480i, 720 x 480p
1280 x 720p, 1920 x 1080i
Dolby AAC, AC-3, MPEG-1 Layer 1,2 and 3
Streo/Joint stereo/Mono, Dolby AC-3
32KHz, 44.1KHz and 48KHz(According to input)
Main System
Main Processor
Memory STi chipset
Flash-ROM : 32 Mbyte
SDRAM : 192 MBytes
EEPROM : 128 bytes
Audio / Video & Data IN/OUT
TV SCART
VCR SCART
RCA
Component
HDMI
OPTIC
RS-232C
USB
e-SATA RGB, Y/C, CVBS Video, Audio L, R Output
RGB Video input, CVBS Video, Audio L, R Input
CVBS Video Output, Audio L, R Output
YPbPr Video Output
AC-3 Dolby Digital (SPDIF)
9 pin D-SUB (Male) type, Transfer rate 115Kbps
USB 2.0 Host Support (Front & Rear)
External SATA HDD Support
Front Panel
Slot
Display
Buttons
1 USB 2.0 Host port
2 Common interface & 2 Smart Card Slot
VFD(Vacuum Fluorescent Display) - 12Digit
5 Buttons(Standby, CH UP/DOWN,
Volume UP/DOWN)
Power Supply
Input Voltage
Type
Power Consumption
Standby Power
Protection
AC 100 ~ 250V, 50/60Hz
SMPS
Max. 60W
Max. 1W
Separate Internal Fuse & Lighting protection
Physical Specification
Size (W x H x D)
Weight (Net)
Operating Temp.
Storage Temp. 340mm X 60mm X 230mm
2.0 Kg
0C ~ +45C
-10C ~ +70C
Старый 12.04.2010, 00:38   #2
andrejkuzma
Ресивер: azbox
andrejkuzma пока неопределено
Дорый день. Чем и как прошивать, этот ресивер. Буду благодарен за инф.
andrejkuzma вне форума   Ответить с цитированием
Обсуждение Openbox S7 HD TWIN PVR SLAVASAM Openbox HD 62 07.12.2022 22:03
Fortis TWIN FS-9200HD PVR Admin Другие HDTV ресиверы 1 24.10.2011 21:19
Xtrend ET9000 HD Twin (Clarke-Tech ET9000) paska Xtrend / World Vision 0 25.09.2011 22:07
Ultraplus F-9000HD twin tuner PVR Admin Другие HDTV ресиверы 0 15.09.2009 20:39
Прошивки Golden Interstar S508 Twin PVR SCAH Софт для Golden Interstar 0 10.09.2009 08:29
Текущее время: 20:18. Часовой пояс GMT +3.
