На форуме: 4
Вернуться   Форум VolSat > Спутниковые ресиверы > Спутниковые HDTV/MPEG4 Ресиверы > Другие HDTV ресиверы
Старый 01.11.2019, 23:02   #1
По умолчанию AB CryptoBox 800UHD
AB CryptoBox 800UHD, еще один спутниковый ресивер 4K UHD
Характеристики:
Support UHD 4K resolution and codec H.265 HEVC
Retained functionality from the previous model
Simply installation – setting receiver in two steps (actually for SK/CZ)
FastScan – quick setting tv actually for SK/CZ/PL/NL programs
Auto FastScan – automatically settings a new tv programs (actually for SK/CZ)
Time Shift recording and PVR function with supported High-speed and Full-speed devices
Supported many kind of storage, recording, playing and connecting many kind of USB equipment
Support for USB 3G modems
PIG ( Picture in Graphic )
FTP manager, games, weather and many more…
Automatic PAL / NTSC conversion
26 the favorite groups
New CPU 1GHz with chipset ALI M2661
16 MB Flash Memory
256 Mbyte DDRIII Memory
1x DVB-S2X tuner
1x Card Reader
1x HDMI port
1x RS232
2x USB 2.0 ( 1x Front, 1x Rear panel )
1x LAN RJ 45
1x S/PDIF optical digital audio output
7 segment Display
7-day electronic guide
Tuner & Channel
Input impedance 75Ω
Input frequency 950~2150MHz
Symbol rate QPSK 1~45Mbauds;
8PSK 2~30Mbauds
Tuner ALI-3031B
Demodulation QPSK.8PSK,16APSK,32APSK
Video
H.265 MP@level 5.1 Main Tier
H.264 BP/MP/HP@level4.1
Video coding provides VBR and CBR model
Low latency coding
Audio
MPEG L1/L2
Dolby Digital/Dolby Digital Plus Decoder-Converter
AAC-LC,HE AAC V1/V2,APE/FLAC/Ogg/AMR-NB/WB,G.711(u/a),Dolby MS11,HE-AAC transcoding DD
Graphics and display
Input Frequency
4K ultra- High definition supported
Maximum & Auxiliary channel supported
4Kx2K@60fps,10bit decoding supported
Video / Audio Decoder
Support H.265 4K*2K@60fps decoding
Support low latency vedio decoding
Support multi-channel decoding simultaneous
Support DRA decoding,
Dolby Digital/Dolby Digital Plus Decoder-Conv,
Dolby True HD/DTS/DTS HD Core decoding; supported Dolby Digital/ DTS
DVB Function
Audio,Video format supported
Support Favorite/Sort/Move/Delete/Edit
Support network search/auto search and TP search
EPG/Subtitle/Teletext Supported
USB, network, actory recovery, upgrade Supported
Multi-language DVB Subtitle output
Dvb subtitle
Other
Support PVR, Timeshift
Support Network protocol http/ https, RTSP, RTMP, HLS
Support weather forecast, show the weather information of the pre-set city
Support multimedia playing , visible communication, multi-screen transcoding and so on function
Support Network driver Ethernet, WiFi 5370/7601/8188 by USB2.0
Support RSS news
Support multi-formats PAL, NTS
Support picture dimension adjusting according screen size
ACM
T2MI
PLSN
Multistream
Device Parameter
Power dissipation 10Wmax
Input voltage AC100~240V, 50/60Hz
Temperature 0 ~ 40℃
Size 180*128*35mm
Licence Dolby Digital & Dolby Digital Plus
Licence CE
Тип файла: jpg 001.jpg 19.4 Кб 23
Тип файла: jpg 002.jpg 27.8 Кб 15
Тип файла: jpg 003.jpg 26.0 Кб 9
Старый 01.11.2019, 23:07   #2
Рекомендованная цена 89 Евро.
Ну я так понял сейчас десятки брендов просто завалят дешевыми ресиверами 4К UHD DVB-S2X на проце от ALI
Осталось подождать немного...
Старый 01.11.2019, 23:22   #3
Marjan0506
Аватар для Marjan0506
ціна 2268 грн.
Старый 02.11.2019, 07:02   #4
ціна 2268 грн.
Когда будет массовое производство таких 4К UHD ресиверов на процах ALI, то цены будут падать. Если сейчас тот же HD BOX S4K COMBO
в розницу стоит 60-65 $, то массовый выпуск снизит цену на такие решения.
Другое дело для той же Украины нужен дешевый с СI+ под модуль XTRA TV, как "ответка" операторскому оборудованию, и как можно дешевле...Просто ресивером с шар****гом сейчас никого НЕ удивишь. Существуют же телевизоры 4К с AndroidOS и Linyx и слот CI+ всегда при них...
Последний раз редактировалось users12; 02.11.2019 в 08:05.
Старый 15.11.2019, 00:49   #5
romario79
Ресивер: Openbox AS4K CI Pro Plus
romario79 немного плохого в прошлом
Видел его за 69 евро
romario79 вне форума   Ответить с цитированием
Старый 15.11.2019, 04:37   #6
Сообщение от romario79 Посмотреть сообщение
Да так и есть. Будут появляться у всех брендов и цены будут всё ниже и ниже.
Старый 26.11.2019, 22:18   #7
Прошивка. Вероятно первый релиз, и нет никаких подробностей.
Тип файла: zip 800UHD_MCAS_V1.09.21048_25-10-2019.zip 4.24 Мб 6
Старый 26.11.2019, 22:49   #8
Есть первые обзоры на Ютубе, кому интересно, результат Поиска выдаёт несколько роликов.
Старый 01.12.2021, 22:37   #9
zasana68
Ресивер: GS-t26
zasana68 пока неопределено
По умолчанию Все о ресивере AB CryptoBox 800UHD
Сегодня AB CryptoBox 800UHD данный ресивер купил через интернет-магазин по акции за 1530 грн. Купил на замену ресивера gi s8120 hd (Spark-1, Enigma2) на перспективу из-за новых форматов вещания. Буду знакомиться с ним. А судя по обзорам о данном ресивере - нормальный, имеет свою операционную систему. Главное не андроид со своими затыками и глюками.
zasana68 вне форума   Ответить с цитированием
AB CryptoBox Meter DVB-S2 sparkT2 Приборы для настройки антенн 11 27.03.2025 21:26
AB CryptoBox Meter DVB-S2 Нет зарядки АКБ - опознание елементов ! Rizla Приборы для настройки антенн 2 16.10.2019 22:17
AB Cryptobox 500mini HD CHOA Другие HDTV ресиверы 9 20.01.2017 20:51
Cryptobox 600HD-новинка gurasik431 Другие HDTV ресиверы 0 13.01.2014 10:32
Текущее время: 04:12. Часовой пояс GMT +3.
