На форуме: 29
Вернуться   Форум VolSat > Спутниковые ресиверы > Enigma 2 Linux Based Receivers > Plugins, EMU, Picons и Skins для Enigma2 > EMU (Эмуляторы) для Enigma2
Старый 23.05.2009, 01:37   #1
leopold75
Аватар для leopold75
leopold75 пока неопределено
По умолчанию MBox
0.5 BETA build 0021 FIX 2
-Via smart card init fix.Endless loop.
-Priority system fix.
-Added multi ecm pid streaming for Azbox receivers(Elite/Premium), max ECM filters/pids is 4.
-Protocol version from this build is 01.07.
-Added allow.list file.Put the file in K path.
-Fix lock up if card init failed in some situations.
-Protocol version is 01.06 .
-Added Conax smart card ECM decoding(EMM for Via,Seca and Conax still pending).
-From this build protocol "version" is 01.06
-Changed how MSMS works, added msmspeer.txt file.
-Changes in code for Azbox smart card reading.
-From this build protocol "version" is 01.05
-Fixed card worker thread code.
-Added Via smart card ECM decoding(EMM for Via and Seca still pending)
-Few changes in MSMS message code(No OSD yet).
-Fix bug that cause crash on Azbox after sending 5-times ECM with no DCW back.
-Changed S line for sssp, now S: { com_device baud } , valids baud -> 115200,57600,38400,19200,9600
-Added sending MSMS messages to peers.
-camd.socket parsing fix.
-From this build protocol version is 01.04
-Fixed bug on resharing ECM.
-Fixed again detection of some boxes.
-Added keep alive flag to MBOX TCP connection.
-Remove some restriction from priority card code.
-Fixed nasty bug where mbox didnt send ECMs after channel changing from seca to n3 or vice versa.
-Fixed detection of some boxes.
-Fixed adding same ECM in cache buffer even if it allready there :S.
-Fixes , fixes and fixes.
Download:
http://www.exyusat.com/mbox/index.ph...ownload&id=248
Мой тюнер: IPbox9000 rel.2(HDD Hitachi 350G) and EVO Infinity
Мои спутники:Yota1.10 and Kharkiv 0.9 (90°E ~ 30°W)
leopold75 вне форума   Ответить с цитированием
Текущее время: 14:02. Часовой пояс GMT +3.
