На форуме: 32
Старый 06.12.2014, 14:37   #221
500sven
Ресивер: open730
500sven может только надеятся на улучшение
LOG000]2014/12/03 16:47:31 1616 s 0 lengths for caid guessing loaded
[LOG001]2014/12/03 16:47:31 1616 s monitor: initialized (fd=7, port=988)
[LOG002]2014/12/03 16:47:31 1616 s camd 3.3x: disabled
[LOG003]2014/12/03 16:47:31 1616 s camd 3.5x: disabled
[LOG004]2014/12/03 16:47:31 1616 s cs378x: disabled
[LOG005]2014/12/03 16:47:31 1616 s newcamd: disabled
[LOG006]2014/12/03 16:47:31 1616 s radegast: disabled
[LOG007]2014/12/03 16:47:31 1616 s logger started (pid=1617)
[LOG008]2014/12/03 16:47:31 1616 s resolver started (pid=1618, delay=30 sec)
[LOG009]2014/12/03 16:47:31 1616 s proxy started (pid=1619, server=5.61.39.129)
[LOG010]2014/12/03 16:47:31 1619 p02 proxy 5.61.39.129:7000 newcamd525 (fd=4)
[LOG011]2014/12/03 16:47:48 1616 s client(1) connect from 192.168.0.224 (pid=1620, pipfd=12)
[LOG012]2014/12/03 16:47:48 1620 m01 plain monitor-client 192.168.0.224 granted (monitor, lvl=4)
[LOG013]2014/12/03 16:48:40 1616 s userdb reloaded: 2 accounts freed, 2 accounts loaded
[LOG014]2014/12/04 18:11:59 1616 s userdb reloaded: 2 accounts freed, 2 accounts loaded
[LOG017]2014/12/06 10:20:23 11898 m01 plain monitor-client 192.168.0.224 granted (monitor, lvl=4)
[LOG018]2014/12/06 10:20:33 1616 s userdb reloaded: 2 accounts freed, 2 accounts loaded
[LOG019]2014/12/06 11:30:53 1616 s userdb reloaded: 2 accounts freed, 2 accounts loaded
[LOG020]2014/12/06 11:31:01 1616 s userdb reloaded: 2 accounts freed, 2 accounts loaded
[LOG026]2014/12/06 11:31:17 12107 m01 plain monitor-client 192.168.0.224 granted (monitor, lvl=4)
[LOG025]2014/12/06 11:31:17 1616 s client(1) connect from 192.168.0.224 (pid=12107, pipfd=12)
[LOG024]2014/12/06 11:31:16 12106 m01 monitor disconnected from 192.168.0.224
[LOG023]2014/12/06 11:31:04 12106 m01 plain monitor-client 192.168.0.224 granted (monitor, lvl=4)
[LOG022]2014/12/06 11:31:04 1616 s client(1) connect from 192.168.0.224 (pid=12106, pipfd=12)
[LOG021]2014/12/06 11:31:02 11898 m01 monitor disconnected from 192.168.0.224
[LOG016]2014/12/06 10:20:23 1616 s client(1) connect from 192.168.0.224 (pid=11898, pipfd=12)
[LOG015]2014/12/04 18:12:15 1620 m01 monitor disconnected from 192.168.0.224
500sven вне форума   Ответить с цитированием
Старый 06.12.2014, 14:38   #222
500sven
Ресивер: open730
спс надеюсь на помощь
Старый 06.12.2014, 15:07   #223
rasm
Аватар для rasm
ещё нужно стать на закодированный канал и снять лог...
то судя по логам -- нет запроса с тюнера
Старый 06.12.2014, 15:20   #224
500sven
Ресивер: open730
Это я стою на канале
Старый 06.12.2014, 15:39   #225
rasm
Аватар для rasm
тогда постой подольше...
я не вижу запросов с тюнера....
Старый 06.12.2014, 15:45   #226
500sven
Ресивер: open730
Через комп мпс показывает.
Стоял я очень долго.
Выбило на роутре когда долго стоял на закрытом канале.
Старый 06.12.2014, 15:57   #227
rasm
Аватар для rasm
настройки mpcs.conf покажи....
Старый 06.12.2014, 16:01   #228
rasm
Аватар для rasm
нет запроса с тюнера...или в настройках кака или со шнурком проблема...
Старый 06.12.2014, 16:10   #229
500sven
Ресивер: open730
[global]
Nice = -2
LogFile = /dev/null
ClientTimeout = 10
ClientMaxIdle = 99999
CacheDelay = 120
[monitor]
Port = 988
NoCrypt =127.0.0.1
NoCrypt = 1.0.0.0-255.255.255.255
AULow = 120
MonLevel = 4
[serial]
# Device = tuner@/dev/ttyS0?delay=2&timeout=1500
Старый 06.12.2014, 17:04   #230
rasm
Аватар для rasm
Разремарь последнюю строчку!!!
# Device = tuner@/dev/ttyS0?delay=2&timeout=1500 -- убери впереди #
Поэтому и нет ничего...мпсс не знает куда слать....
Старый 06.12.2014, 17:50   #231
500sven
Ресивер: open730
спс заррраааааботало
Старый 09.12.2014, 22:45   #232
niger
niger немного плохого в прошлом
[LOG013]2014/12/09 8:47:11 4789 s resolver started (pid=4792, delay=30 sec)
[LOG014]2014/12/09 8:47:11 4789 s proxy started (pid=4793, server=s1svoehd.net)
[LOG026]2014/12/09 8:47:15 4816 m02 plain monitor-client 192.168.11.211 granted (monitor, lvl=4)
[LOG025]2014/12/09 8:47:15 4789 s client(2) connect from 192.168.11.211 (pid=4816, pipfd=13)
[LOG024]2014/12/09 8:47:15 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG023]2014/12/09 8:47:15 4793 p02 server does not return 14 bytes
[LOG022]2014/12/09 8:47:15 4794 c01 plain dsr9500-client 127.0.0.1 granted (anonymous, au=0)
[LOG021]2014/12/09 8:47:15 4794 c01 detected dsr9500-extended type receiver
[LOG020]2014/12/09 8:47:14 4815 m02 plain monitor-client 192.168.11.211 rejected (invalid access)
[LOG019]2014/12/09 8:47:14 4789 s client(2) connect from 192.168.11.211 (pid=4815, pipfd=13)
[LOG018]2014/12/09 8:47:12 4814 m02 plain monitor-client 192.168.11.211 rejected (invalid access)
[LOG017]2014/12/09 8:47:12 4789 s client(2) connect from 192.168.11.211 (pid=4814, pipfd=13)
[LOG016]2014/12/09 8:47:11 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG015]2014/12/09 8:47:11 4789 s serial: initialized (pid=4794, auto@/dev/ttyATH0)
[LOG027]2014/12/09 8:47:17 4793 p02 server does not return 14 bytes
[LOG028]2014/12/09 8:47:17 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG029]2014/12/09 8:47:20 4793 p02 server does not return 14 bytes
[LOG030]2014/12/09 8:47:20 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG031]2014/12/09 8:47:22 4793 p02 server does not return 14 bytes
[LOG032]2014/12/09 8:47:22 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG033]2014/12/09 8:47:22 4793 p02 server does not return 14 bytes
[LOG034]2014/12/09 8:47:22 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG035]2014/12/09 8:47:24 4793 p02 server does not return 14 bytes
[LOG036]2014/12/09 8:47:24 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG037]2014/12/09 8:47:25 4794 c01 anonymous (0500&040600/284A/5F:CDE5): timeout (10007 ms)
[LOG038]2014/12/09 8:47:30 4794 c01 anonymous (0500&040600/3AFF/557AD): timeout (10009 ms)
[LOG039]2014/12/09 8:47:32 4794 c01 anonymous (0500&040600/3AFF/55:E8AD): timeout (10016 ms)
[LOG040]2014/12/09 8:47:32 4793 p02 server does not return 14 bytes
[LOG041]2014/12/09 8:47:32 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG042]2014/12/09 8:47:35 4793 p02 server does not return 14 bytes
[LOG043]2014/12/09 8:47:35 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG044]2014/12/09 8:47:42 4794 c01 anonymous (0500&040600/3AFF/55:E3AD): timeout (10001 ms)
[LOG045]2014/12/09 8:47:42 4793 p02 server does not return 14 bytes
[LOG046]2014/12/09 8:47:42 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG047]2014/12/09 8:47:45 4793 p02 server does not return 14 bytes
[LOG048]2014/12/09 8:47:45 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG049]2014/12/09 8:47:52 4794 c01 anonymous (0500&040600/3AFF/55:F4AD): timeout (10003 ms)
[LOG050]2014/12/09 8:47:53 4793 p02 server does not return 14 bytes
[LOG051]2014/12/09 8:47:53 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG052]2014/12/09 8:47:54 4793 p02 server does not return 14 bytes
[LOG053]2014/12/09 8:47:54 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG054]2014/12/09 8:48:02 4794 c01 anonymous (0500&040600/3AFF/55:0FAC): timeout (10005 ms)
[LOG055]2014/12/09 8:48:02 4793 p02 server does not return 14 bytes
[LOG056]2014/12/09 8:48:02 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
[LOG057]2014/12/09 8:48:05 4793 p02 server does not return 14 bytes
[LOG058]2014/12/09 8:48:05 4793 p02 proxy s1svoehd.net:7000 newcamd525 (fd=4)
а с друго шаровни ввожу настройки все работает
niger вне форума   Ответить с цитированием
Старый 09.12.2014, 23:24   #233
pizdryk
Ресивер: Sezam Marvel, Sezam 5000
Поблагодарили 143 раз(а) в 67 сообщениях
pizdryk скоро придёт к известности
В вашем случае эмулятор не может подключиться к серверу кардшаринга. Или прописаны неправильные параметры для сервера, или сам сервер нерабочий.
вместо доменного имени забей в конфиг 5.61.39.129 или в настройках сети забей ДНС гугла 8.8.8.8
pizdryk вне форума   Ответить с цитированием
Старый 10.12.2014, 11:37   #234
niger
[account]
user = root
pwd = root
group = 1
monlevel = 4
[reader]
enable = 1
label = HTB+ 36E
protocol = newcamd525
key = 0102030405060708091011121314
device = s1svoehd.net,7000
account =
caid = 0500
ident = 040600,040620,050B00
group = 1
fallback = 0
reconnecteimeout = 1
inactivitytimeout = 0
[global]
Nice = -2
LogFile = /dev/null
LogFile = stdout
ClientTimeout = 10
CacheDelay = 120
globo = 1
[monitor]
Port = 988
NoCrypt =192.168.1.1
AULow = 120
MonLevel = 4
[serial]
Device = auto://tuner@/dev/ttyATH0?delay=2&timeout=1500
Старый 10.12.2014, 12:49   #235
rasm
Аватар для rasm
не хватает секции в файле mpcs.user:
[account]
User = tuner
Pwd = tuner
Group = 1
IDENT = 0500:040600,040620,050B00
Старый 10.12.2014, 14:14   #236
niger
ну да mpcs.user такойже как написали а лог вот:
Старый 10.12.2014, 15:44   #237
вы попробовали, как вам подсказали, вместо доменного имени вбить адрес?
Старый 10.12.2014, 16:35   #238
rasm
Аватар для rasm
anonymous (0500&040600/284A/5F:CDE5): timeout (10007 ms) -- не могу понять, почему anonymous?
запрос с тюнера, вроде есть, то ответ ананимусу....неверно...должен быть тюнер
ЗЫ...если то другого шародателя, все настройки теже, работает, то возможнл в этом шародателе проблема?
Старый 10.12.2014, 19:10   #239
niger
на других плагинах работает
Старый 10.12.2014, 19:11   #240
niger
а вот wicard в роутер загнать низнаю как. и вообще у меня wicard для tp-link нет
FAQ по роутеру TP Link 3220 sat78 Модемы, Роутеры, WiFi точки доступа 39 07.11.2019 19:12
роутер TP Link 3220 и 4 компьютера sat78 Модемы, Роутеры, WiFi точки доступа 4 12.03.2013 13:54
Текущее время: 16:26. Часовой пояс GMT +3.
