На форуме: 36
Старый 31.08.2013, 21:40   #1
xella
Сказал(а) спасибо: 300
По умолчанию Реанимация ресиверов Openbox HD
Коды ошибок загрузчика
3:
№ Код Значение Состояние Решение
1 0x00 Нет ошибок Нет ошибок
2 0x01 Application Error Error on Application sector Download s/w(*.ird) via Serial
3 0x02 BlockXpress Error on releasing condensation Check RAM and related circuit
4 0x03 InvalidFlash No supported Flash Memory
5 0x04 Security Main BCB Check security chip and related circuit on main board
6 0x05 Security Front PCB Check security chip and related circuit on front board
7 0x10 SystemId Different System ID Check System ID of s/w in receiver and that of a new s/w
8 0x11 Range Overcapacity of downloading file Delete useless language and secure capacity
9 0x12 UartTimeOut Error on Serial communication Close all the programs except download program in PC
10 0x13 BlockCrc Error on downloaded s/w(*.ird) Download s/w(*.ird) again
11 0x14 DataType No supported data type
12 0x15 XfdVer No supported s/w version
13 0x20 OtaCancel Cancel OTA
14 0x21 OtaTimeOut OTA is not finnished within the time
15 0x22 OtaCrc32 Problem on OTA file
16 0x23 OtaNoNIT[2]
17 0x24 OtaNoSVC No locking with OTA TP Check antenna cable connection
18 0x25 OtaNoDSI[2]
19 0x26 OtaNoDII[2]
20 0x27 OtaNoDDB[2]
21 0x28 OtaNewDSI[2]
22 0x70 Kernel Kernel Error Downlaod s/w(*.ird) again
23 0x71 rootfs rootfs Error Downlaod s/w(*.ird) again
24 0x72 device fs Device file system error Downlaod s/w(*.ird) again
25 0x80 FlashWriting Error during wrting on Flash Check Flash related circuit
26 0x81 EepromWriting Error during wrting on Eeprom Check Eeprom related circuit
27 0x82 XfdmWriting IRD Write ERROR Check Flash related circuit
28 0x83 EepromReading Error on reading Eeprom Check Eeprom related circuit
29 0x90 USBNotFound Error on finding USB device No supported USB device, change USB device
30 0x91 USBFatReadErr Error on reading FAT in USB device Format USB device with FAT
31 0x92 USBFileFound Error on finding s/w (*.ird) in connected USB device Check the existence of s/w (*.ird) in USB device
32 0x93 USBReadErr Error on reading s/w(*.ird) in the connected USB device Format USB device with FAT, copy s/w to the USB device, and then download it again(*.ird)
33 0x94 USBDecompErr Error on reading s/w(*.ird) in the connected USB device Format USB device with FAT, copy s/w(*.ird) to the USB device, and then download it again
Новые версии загрузчиков для S4/S4Pro+/S6/S6+/S6Pro/S6Pro+
Исправлено
- ресивер не загружается и зависает с надписью Load на дисплее.
3:
1. Подготовка USB накопителя
* Подготовьте USB накопитель.
* Файловая система должна быть FAT32.
* Рекомендуется высокоскоростной USB накопитель.
(Установка может не получиться, если флешнакопитель старый или медленный)
2. Установка нового загрузчика
* На USB накопителе должен быть только файл загрузчика в формате .ird
* Вставить USB накопитель в ресивер, включить питание, предварительно зажать и удерживать кнопку CHANNEL UP на лицевой панели ресивера пока не появится надпись SCAN.
* По окончании установки появится надпись COMPLETE, перезагрузите ресивер, новый загрузчик установлен.
Тип файла: rar UpdateLoader.OPENBOX.S4 HD PVR.L6.47.rar 113.1 Кб 412
Тип файла: rar UpdateLoader.OPENBOX.S4 Pro plus.L7.07.rar 130.8 Кб 485
Тип файла: rar UpdateLoader.OPENBOX.S6 HD PVR.L6.27.rar 112.7 Кб 627
Тип файла: rar UpdateLoader.OPENBOX.S6 Pro HD PVR.L6.37.rar 113.1 Кб 311
Тип файла: rar UpdateLoader.OPENBOX.S6 pro plus.L7.37.rar 131.4 Кб 354
Тип файла: rar UpdateLoader.OPENBOX.S6plus HD.L7.27.rar 130.8 Кб 432
Одним Бог дал крылья, а другим - хорошего пенделя... И вроде бы все летят, но какие разные ощущения и перспективы!!!
Старый 31.08.2013, 21:43   #2
xella
Сервисный файл для чистки памяти ресиверов OPENBOX S4/S6/S6Pro.
3:
Метод применения:
* На USB накопителе должен быть только сервисный файл в формате .ird
* По окончании установки появится надпись COMPLETE, перезагрузите ресивер, ваш ресивер чист как с завода.
Скрытый текст (вы должны войти под своим логином или зарегистрироваться и иметь 10 сообщение(ий)):
Тип файла: rar Cleanup_CUE_v2_S4.rar 308 байт 552
Тип файла: rar Cleanup_CUE_v2_S6.rar 308 байт 613
Тип файла: rar Cleanup_CUE_v2_S6Pro.rar 320 байт 451
Старый 31.08.2013, 22:23   #3
sokol2007
Ресивер: Gi8120
Сказал(а) спасибо: 113
Я извиняюсь может не в тему,уж очень хочется задать вопрос,а эта прога поможет если на панели ресивера горит только надпись Openbox и не на что больше не реагирует...
Старый 01.09.2013, 15:51   #4
xella
Клинический случай. Ремонт только в СЦ , либо у квалифицированного специалиста по ремонту спутниковых ресиверов.
Старый 01.09.2013, 19:11   #5
Сказал(а) спасибо: 4,494
Сообщение от xella Посмотреть сообщение
Ну да, случай типичный...
Старый 05.10.2013, 06:24   #6
АЛЕКСЕЙ ЕРШОВ
Ресивер: neotion3000
Сказал(а) спасибо: 75
АЛЕКСЕЙ ЕРШОВ пока неопределено
Спасибо!
АЛЕКСЕЙ ЕРШОВ вне форума   Ответить с цитированием
Старый 05.10.2013, 06:28   #7
АЛЕКСЕЙ ЕРШОВ
Спасибо "XELLA" за Update Loader
Старый 05.10.2013, 06:36   #8
АЛЕКСЕЙ ЕРШОВ
У меня вопрос можно ли Update Loader Openbox.S6 plus HD L7.27 применить для HD6+ прошитый под Openbox S6 plus HD
Старый 16.10.2013, 09:55   #9
umid
Ресивер: superbox s750 spark
umid пока неопределено
nujna servisnaya po na s6pro+
umid вне форума   Ответить с цитированием
Старый 16.10.2013, 16:54   #10
xella
umid смотрите в ЛС.
Старый 16.11.2013, 18:25   #11
anatoliykon
Ресивер: SkyWay Platinum UNI BOX9060 gi7699
Сказал(а) спасибо: 27
anatoliykon пока неопределено
скачал прошивку 2.11.77 но с модулем нтв+ си + не работает рес опенбокс с6 про, хотя с 2,11,57 все работало на прошивке октагон что вернутся к ней ,?
anatoliykon вне форума   Ответить с цитированием
Старый 16.11.2013, 20:06   #12
xella
Для ресиверов модели S4 ,S6 , S6 pro ( без + ) существует только адаптированная прошивка (от октагона ) v.2.11.57 с поддержкой CI+. В Вашем случае действительно придется "откатываться" на это ПО.
P.S.anatoliykon Загрузчик менять не нужно.
Последний раз редактировалось xella; 17.11.2013 в 06:53.
Старый 27.01.2014, 20:56   #13
tolian
Ресивер: Openbox S6+HD
tolian пока неопределено
Добрый день всем, Подскажите пожалуйста,после неудачной прошивки Openbox s6+ hd на табло ресивера при включении пишет reboot5,reboot4,reboot3,reboot2,load usb и потом все по кругу,через флешку и rs232 не прошивается.В чем может бить причина и как посмотреть код ошибки?
tolian вне форума   Ответить с цитированием
Старый 27.01.2014, 21:18   #14
Сообщение от tolian Посмотреть сообщение
Если через усб и сом-порт нельзя прошиться, и вы прочитали и испробовали метод, написанный выше парой постов - то ему прямая дорога в сервис, где есть нормальный ЖТАГ...
Старый 27.01.2014, 21:34   #15
tolian
подскажите в каком формате должен бить записан фаил ?
Старый 27.01.2014, 21:59   #16
Этого не видели??? Или уточните, что именно вы хотели нам сказать?
Метод применения:
Старый 03.03.2014, 17:26   #17
fliper
Ресивер: OpenBox SX6 HD + Amiko SHD-8900 Alien
Сказал(а) спасибо: 182
Поблагодарили 57 раз(а) в 29 сообщениях
fliper на пути к лучшему
Скажу сразу не мое, а взято на одном из форумов...
Сервисное ПО для SX6 ---Init Flash v6 OPENBOX SX6 v3.00.99
ДЛЯ ЧЕГО???
Эта прошивка применяется пользователями в случае, если наблюдаются какие-либо проблемы:
а) в работе ресивера
б) при загрузке ПО по USB
в) при загрузке ресивера получаете ошибку на дисплее (RUN..., Err..)
Это ПО полностью очищает память ресивера от всех установленных ранее плагинов и настроек, которые могут негативно влиять на работу ресивера.
КАК ЗАЛИТЬ???
1-ый способ
как обычную прошивку.
то есть-разархивируем файл сервисного ПО и кидаем на флешку.вставляем в ресивер.в любой удобный разъем USB-появляется окно предупреждение с подсказкой на экране ТВ.
жмем цветную кнопку отвечающую за загрузку.
ждем окончания и перегрузки ресивера.
2-ой способ
по методу CHUP.
1. выключаем ресивер задним тумблером
2. на пустой USB накопитель форматированный в FAT32 переносим .IRD файл и соединяем с ресивером.
3. вкл. ресивер задним тумблером и придерживаем на передней панели ресивера кнопку со стрелкой вверх "CHUP" пока на дисплее не появится надпись "SCAN USB" и % загрузки.
4. после появления на дисплее ресивера надписи "Complete" выключаем ресивер в Stand-By, потом задним тумблером.
5. с USB накопителя удаляем загрузчик.
http://yadi.sk/d/Q-DmkI0_JrueT
TV:-Samsung SmartTV UE37D6500VS
fliper вне форума   Ответить с цитированием
Старый 06.03.2014, 20:29   #18
boris.kovalthuk
Аватар для boris.kovalthuk
Сказал(а) спасибо: 1,507
Есть ресивер Openbox S5 HD PVR.
Системная информация:Верс. загрузчика L 2.23.
Аппарат.верс.HS 9510C 1.00.
Верс.приложений HS V 1.08.83.
Верс.данных FDU V 1.3.
Слетели каналы и настройки спутников.При обратном сканировании каналов и обратном вводе портов ресивер работает,но после выключения с сети(розетки),обратно всё слетает и так всё время.Настройки плагинов,ключей,шары не слетают.
Подскажите,с чего начинать,кроме БП,он рабочий.
4W.5Е.13Е.36Е.
Старый 06.03.2014, 20:39   #19
Пробуй перепрошить ресивер с зачисткой всех хвостов. С нуля то есть. Настройки прежде сохрани.
Старый 06.03.2014, 20:44   #20
boris.kovalthuk
Ярослав,если можно,поясни как и какую зачистку делать?Всё удалить и спутники и транспондеры,каналы?Если я сохраню настройки на флешку,то настройки плагинов с шарой тоже на неё будут сохранены?Вот это меня больше волнует.
4W.5Е.13Е.36Е.
Реанимация ресиверов SkyGate FTA, Smart, @NET, HD через COM-Port Admin SkyGate HD 43 22.02.2020 18:22
Реанимация Openbox x-730/750/770CIPVR/790CIPVR Admin Openbox X-730/750/770/790 26 23.12.2013 10:34
Реанимация OpenBox X-540 Agent0327 Схемотехника, Мастерская 25 22.10.2012 19:20
Схемы ресиверов Openbox Stas1969 Схемы 5 14.11.2011 21:55
Текущее время: 23:09. Часовой пояс GMT +3.
