Тем: 4,594, Сообщений: 361,231, Пользователи: 159,965
На форуме: 9
Вернуться   Форум VolSat > Спутниковые ресиверы > Enigma 2 Linux Based Receivers > Kathrein HD
Kathrein HD Kathrein HDTV UFS 902si, Kathrein UFS 904HD, Kathrein UFS 910 HD, Kathrein UFS 912 HDTV
Старый 14.01.2010, 01:42   #1
maral100
Ресивер: openbox 820
Поблагодарили 19 раз(а) в 8 сообщениях
maral100 пока неопределено
По умолчанию Editors, Tools, Plugins для Kathrein
Laforum_z Version Of MultiPart Installer AAF UFS9XX
AAF UFS910/UFS922 MultiPart Installer V1.7c
V1.7c
- fix BA detection for E2 in mini
- fix error create partitonen
- fix question 2bl on
- fix flash image name with spaces or other symbols
- check mini U-boot image name ( no *.tar.gz or *.ipk files allowed )
последняя версия загрузчика с исправлениями
Тип файла: rar AAF_MPI_V1.7c_UFS9xx.rar 2.54 Мб 44
maral100 вне форума   Ответить с цитированием
Старый 01.03.2010, 22:12   #2
maral100
Kathrein Tools
Instalator E2 4 Kathrein_Octagon v-0,7
Код:
1. Installation SoftUSB2 and E2 - in fact, this option should be used only when installing softusb2 and E2 is the first time, or pen-and changed, or damaged we Softusb2, which reveals not display bootmenu. The function of the pen erases all existing partitions, assumes a new, reformats it, installs softusb2, installs and configures the main e2 bootmenu.
2. Installing new version of the E2 (update) - use it when you want to record a new version of the E2 to the already installed in step 1 and existing standard as a 2 point bootmenu. It works only on the installation Świerże E2 and change the entry bootmenu. No other files on the pen are not deleted.
3. Doinstalowanie new firmware E2/neutrino/inne:
- Unpack the downloaded zip file with the soft / zip to a file tar.gz
- Select the advanced options
- Then unpacking / installation of a new distribution of E2
- When asked "Do you unpack the distribution of E2 to the directory?" persons using the EXT3 may respond, depending on preference. People who use the FAT file system this question does not appear.
- When asked "Do you create an image Softusb2?" answer YES
- Choose soft we want. Eg Neutrino_tdt-2001_PKT-178.tar.gz
- We give the name of the created image. Such as neutrino
- Size of the created image can be left to 256MB.
- When you create image entering to the "Manage BootMenu"
- We press download
- Zaznaczamynastępną empty position bootitem
- In the name box type the text you want to appear on the display. Such as neutrino
- Field type always choose e2 for E1/E2/Neutrino/VDR
- Select type field softusb2
- Press the question mark on the right side of the field parameters
- Mark the file you created earlier neutrino.uImage
- Field of parameters, for example, should look for example like this: .. / images / neutrino
- We press Save
- We press download to see if bootmenu been changed
- We close the program and look forward to the new firmware doinstalowanego
4. Doinstalowanego firmware update earlier E2/neutrino/inne:
- Box enter the same image, which was used previously. This will overwrite the old files with new ones.
5. Removing unnecessary entries from bootmenu:
- Run the installer E2
- Enter the advanced options
- Then to manage bootmenu
- Press download
- If you have questions about the type of partition, answer truthfully
- Is characterized by the bootitem you want to delete. Of course you can uncheck any, even the middle. The rest will be poprzesuwana during a write operation
- Press Save and then download the purposes of checking whether our settings are correctly inscribed
6. Improved network configuration:
- Run with the tuner Drivers in flash
- Then telnet
- We press the button "Configure network for E2
- We reaffirm that the tuner is running with the Drivers in flash
- We reaffirm that the tuner is in standby mode
- When asked "Do you use EXT3?" answer YES if softusb2 is installed on your system EXT3, or NO if the FAT
- We provide a correct gateway address
- Changing the mask, if necessary
- Waiting until the completion of the work, which show the information:
-> Uboot (2) network configured
IP address: 192.168.1.7
Netmask: 255.255.255.0
Gateway: 192.168.1.1
Server: 192.168.1.1
/ tmp/configurator/softusb2 #
мой , хоть и кривой , но перевод
Код:
1. установка SoftUSB2  и Е2 (Installation SoftUSB2 and E2) -  эта опция должна использоваться только при первичной установке softusb2 и Е2 , а также при изменении или повреждении  Softusb2, при котором загрузочное меню не отображается. Функция установка SoftUSB2  и Е2 (Installation SoftUSB2 and E2) (заливки,переустановки,стирания) стирает все существующие разделы, создавая (предполагая) новые, форматирует их, устанавливает softusb2, устанавливает и настраивает основные E2 загрузочное меню.
2. Установка новых версий Е2 (обновленная) - используйте ее, если вы хотите,  записать новую версию в то время , как  Е2 уже установлен в  загрузочное меню. Это работает только на установку Swierze Е2 и изменяет запись загрузочного меню. Никаких других файлов  не удаляется.
3. Doinstalowanie -  новая прошивка E2/neutrino/inne:
- Распакуйте  Zip - архив в папку tar.gz
- Выберите дополнительные параметры
- Далее распакуйте и инсталлируйте новый дистрибутив E2
- На вопрос: "Желаете ли Вы распаковать Е2 в каталоге?" ("Do you unpack the distribution of E2 to the directory?" ) - лицам, использующим EXT3 можно  ответить, в зависимости от предпочтений. У людей,у  которых используется файловая система FAT, этот вопрос не возникает.
- На вопрос: "Вы создаете образ Softusb2?"("Do you create an image Softusb2?" )- Отвечайте ДА
- Выбрать софт , который Вам нужен. Например Neutrino_tdt-2001_PKT-178.tar.gz
- Дайте (выберите) название создаваемому файлу . Такой же , как нейтрино
- Размер созданного файла может быть не более  256MB.
- Когда вы создали образ файла, зайдите в   "Управление загрузочным меню"(Manage BootMenu"
- Далее жмите - Скачать(download
- Отметьте далее  пустые boot позиции
- В поле -Тип Название- Текст будет отображаться на дисплее. Такие, как нейтрино
- Тип поля всегда выбирать E2 для E1/E2/Neutrino/VDR
- Выберите тип области softusb2
- Нажмите на знак вопроса на правой стороне поля параметры
- Выберите файл, который вы создали (распаковали) ранее neutrino.uImage
- Область параметров, например, должна выглядеть например так: .. / Images / neutrino
- Нажмите Сохранить
- Нажимаем скачать, чтобы увидеть, было ли  изменено загрузочное меню
- Закрываем программу
4. Обновление более ранних E2/neutrino/inne:
- Распакуйте скачанный файл Zip  в папку tar.gz
- при распаковке / установке нового распределения E2
- на вопрос: "распаковать Е2 в каталоге?" лицам, использующим EXT3 может ответить, в зависимости от предпочтений. Люди, которые используют файловую систему FAT этот вопрос не возникает.
- Когда спросили: "Вы создаете образ Softusb2?" Ответ ДА
- Выбрать прошивку. Например Neutrino_tdt-2001_PKT-178.tar.gz
- Box введет (зальет) тот же самый образ, который был использован ранее. Это будет замещать старые файлы новыми.
- Размер созданного образа может быть оставлена на 256MB.
5. Удаление ненужных записей из загрузочного меню:
- Запуск установки E2
- Введите дополнительные параметры
- Затем зайдите в управление загрузочным меню
- нажать - Скачать(download)
- Если у вас есть вопросы о типе раздела, правдиво ответить
- выберите то , что вы хотите удалить. Конечно, вы можете удалять в любом месте , даже посередине. Все остальное будет сжато и распределено  во время операции записи
- Нажмите Save, а затем перепроверьте правильность написания
6. Улучшенная конфигурация сети:
- Запуск с драйверами тюнера во флэш
- войдите в  дополнительные параметры
- далее Telnet
- Нажимаем кнопку "Настройка сети для E2
- Мы подтверждаем, что тюнер работает с драйверами в Flash
- Мы подтверждаем, что тюнер находится в режиме ожидания
- На вопрос: "Используете ли вы EXT3?" Ответ ДА, если softusb2 установлены на вашей системе ext3, или НЕТ, если FAT
- устанавливается  правильный адрес шлюза (порта)
- Изменените маску, если необходимо
- Ожидание до завершения работ, которые показывают информацию:
-> Uboot (2) сеть настроена
IP адрес: 192.168.1.7
Маска сети: 255.255.255.0
Шлюз: 192.168.1.1
Сервер: 192.168.1.1
/ Tmp/configurator/softusb2 #
Тип файла: zip Instalator E2 4 Kathrein Octagon v-0,7.zip 2.66 Мб 18
Старый 17.03.2010, 22:04   #3
maral100
Instalator E2 4 Kathrein_Octagon v-0,8
Код:
- We press download
- We press Save
- Press download
- If you have questions about the type of partition, answer truthfully ;-)
- Then telnet
Тип файла: zip Instalator E2 4 Kathrein_Octagon v-0_8.zip 3.75 Мб 36
Старый 11.04.2010, 18:25   #4
maral100
Kathrein Tools
Mini-uboot Instalator 0.85
Код:
Miniuboot an alternative to the 2nd boot-loader and softusb2. Generally, the task is exactly the dock ³ same, ie allows you to choose the firmware that runs at startup like those tunera.I solution to OSA can e ³ u ¿insert to 9 of different image.
Basic differences:
- Miniuboot does not require any special firmware for operation. Because of its ¹ Size upload to a place of dot ¹ d ¿unused used by the system.
- Miniuboot image allows you to update via USB. Doœæ valuable, as it is uploaded to the flash E2, or Neutrino when ¿in both cases are solved on a standard partition of emergency serv ¹ ca supports firmware update with USB.
- Miniuboot NOT allow you to run the firmware via NFS, with only a flash and USB
- Ka ¿dy soft ¹ must have a separate partition (like uboocie choice of firmware)
- Implemented functions and fatload speedboot przyœpieszaj head will start the process of firmware with a pen-
Required programs:
- AAF multipart Installer v1.9
- CreateMini V1.4, if we want a more advanced zrobiæ ³ ¹ configuration (see section 5)
1st Installation miniuboot:
- Running MPI 1.9
- Configure the IP address if needed
- Press the button "Connect"
- After a while you press the button "Mini U-Boot"
- Press the button "Install Mini U-Boot"
- After installation should uaktualniæ przcisk yourself to "Deactivate"
2nd Recording Neutrino Flash using MPI 1.9 ¹:
- Running MPI 1.9
- Press the button "Flash Tool"
- In the "Select Full Image" choose the downloaded flash Neutrino.
- Press "Flash full" and waiting quietly at the end of the operation
3rd Recording to flash the firmware via USB:
- Check if you have the appropriate firmware ¹ ¹ in flash command cat / proc / mtd "
If you returned a dock ³ exactly the same as below, you can dalesz
Running a Started
размер файла 3,19 мб.
Скачать
Старый 20.04.2010, 18:25   #5
maral100
Mini-uboot Instalator 0.86
Код:
Basic differences:
Required programs:
- Running MPI 1.9
- Running MPI 1.9
Running a Started
Код HTML:
http://depositfiles.com/files/zp4i880lx
Plugins & Transponders auto download oktagon Плагины/Plugins 1 05.11.2012 15:20
Plugins для Azbox HD Admin Azbox HD 9 03.11.2009 09:59
Инструменты/Tools Admin Editors, Tools, Plugins AB IPBOX HD 2 01.06.2009 08:27
Plugins Admin Editors, Tools, Plugins для Dreambox 6 04.03.2009 10:13
Текущее время: 02:16. Часовой пояс GMT +3.
