#1021 |
![]() Регистрация: 18.12.2009
Ресивер: GI-8120,dbox2
Сказал(а) спасибо: 13
Поблагодарили 119 раз(а) в 52 сообщениях
Вес репутации: 16 ![]() |
Уважаемые кто поможет с настройками конфг викарда чего то подвисает шара ,вот мои конфигурации
[global] active = 1 log_udp = 192.168.1.2:514 ip компа log_size = 30 syslog = 1 debug = 3 daemon = 1 [webif] active = 1 port = 8080 [dvb] active = 1 type = DVBAPI3 filter = dvb rerequest_not_decoded = 1 debug = 1 #dre_fix = 1 auto_update = 1 [filter] name = dvb rule = caid=2600;ident=0;sid=000D,17ED,0001,0003,1B4E,17E 8,19D2,1A18,17DE,000C,0004,000B,0065,1D33;accept rule = caid=0D03;accept rule = caid=093e,090F;ident=0;accept #VIASAT rule = caid=4ae1;ident=0,11,15;ident:=0;accept # tricolor rule = caid=2710;ident=000000,000006;accept #lebed tv rule = caid=1803;ident=007001,007101,000000;accept #Cyfrowy Polsat rule = caid=0100;ident=000068;accept #Cyfra+ rule = caid=0500;ident=040600,040620,023100,032500,041700 ,042200,042300,042700,042800,040810,042400,043800, 032830,024F00,024700,023800,020A00;accept #all viaccess rule = reject [reader] active = 1 name = NTV type = newcamd525 account = xxxxxx:xxxxxx@xxxxxxx:xxxx:01020304050607080910111 21314 debug = 1 reconnect_delay = 10 emm_cache = 1 [reader] active = 1 name = Lebed' TV type = newcamd525 account = xxxxxx:xxxxxx@xxxxxx:xxxx:010203040506070809101112 1314 debug = 1 reconnect_delay = 10 emm_cache = 1 [reader] active = 1 name = TRICOLOR type = newcamd525 account = :xxxxxxx@xxxxx:xxxx:0102030405060708091011121314 debug = 1 reconnect_delay = 10 emm_cache = 1 [reader] active = 1 name = TRICOLOR type = newcamd525 account = :xxxxxx@xxxxx:xxxx:0102030405060708091011121314 debug = 1 reconnect_delay = 10 emm_cache = 1 [reader] active = 1 name = XXX type = newcamd525 account = xxxxxxx:xxxxx@xxxxx:xxxx:0102030405060708091011121 314 debug = 1 reconnect_delay = 10 emm_cache = 1 [reader] active = 1 name = Biss type = emubiss file = /root/plugin/var/keys/SoftCam.Key filter = dvb ecm_queue_size = 8 debug = 1 |
#1022 |
![]() Регистрация: 18.06.2013
Сказал(а) спасибо: 276
Вес репутации: 16 ![]() ![]() ![]() |
Так какие пакеты подвисают? Какой ресивер? Тут есть явно лишние пробелы и лишние двоеточия...
Для Триколора нужны иденты 0,11,02, а зачем 15?
" Учимся говорить правильно! Не путаем ресивер и тюнер. Ведь в одном ресивере может быть несколько тюнеров! " |
#1023 |
#1024 |
Для Триколора обычно достаточно
rule = caid=4ae1;ident=0,11,02;ident:=0;accept НТВ все правильно, сколько мс идут ответы для НТВ+ ? Если вы подключены к перекупщикам, так и ответы будут идти долго и будут затыки...
#1025 |
думаю что не перекупщики это plitv.tv а мс сейчас 633-835
#1026 |
Ну конфиг нормальный, нужно поставить везде debug = 1, зачем вебинтерфейс? поставьте active = 0, а в ридер НТВ filter = dvb и ecm_ttl = 15000
#1027 |
#1028 |
![]() У меня прописано везде, кроме ридера на BISS
#1030 |
#1031 |
Нужно аккуратно прописывать, лишний пробел может быть критичен. Использовать правильный редактор, а не Блокнот. Прописали строчку - запустили посмотрели проверили, как работает, а не пошло тут же ее убрали.
И действительно большинство же дают рекомендованные настройки...
#1032 | |
#1033 |
![]() Регистрация: 09.03.2010
Сказал(а) спасибо: 163
Если подвисают НТВ - пересканируйте транспондеры с удалением предыдущих сканов.
E2, mgcamd 1.38a, wicardd 1.18, oscam-ymodv18-t56 |
#1034 |
![]() Регистрация: 19.07.2012
Сказал(а) спасибо: 18
Вес репутации: 0 ![]() ![]() |
для тебя так
[global] active = 1 #log = /tmp/wicardd.log log_udp = 192.168.0.44#IP компа log_size = 100 debug =1 [webif] port = 8080 debug = 3 active = 1 [dvb] active = 1 type = DVBAPI3 filter = dvb debug = 1 ecm_info = 1 sdt = 1 rerequest_not_decoded = 1 [filter] name = dvb rule = caid=2600;accept=BISS rule = caid=4AE0,4AE1;ident=11;caid:=4AE1;ident:=11;accep t=shara4120#Tricolor# так прописано, чтобы канал A-One работал rule = caid=0500;ident=040600,040620,042300,041200,41700, 43800;accept=shara4100#NTV rule = caid=0B0F;ident=0;accept=shara4135#xtra rule = caid=093E;ident=0;accept=shara4131#VIASAT rule = caid=090f;ident=0;accept=shara4130#VIASAT rule = caid=0652;ident=0,15,ffff;accept=shara4205#Raduga rule = caid=2710;ident=0,6;accept=shara4125#lybed rule = caid=0100;ident=0,68;accept=shara4235#Cyfra+ rule = caid=1803;ident=0,007101;accept=shara4230#Cyfrowy_ Polsat rule = reject [reader] name = shara type = newcamd525 account = логин:пароль@s4.plitv.tv multiport = 4100,4120,4125,4130,4131,4135,4205,4230,4235 debug = 3 [reader] active = 1 name = BISS type = emubiss file = /var/keys/SoftCam.Key |
#1035 | |
Последний раз редактировалось carlosh; 29.10.2013 в 19:20. |
#1036 |
![]() Регистрация: 29.09.2012
Сказал(а) спасибо: 183
Вес репутации: 13 ![]() |
#1037 | |
#1038 |
Возможно на Энигме он нужен,на Спарке всё норм и без него работает а темболее на wicardd 1.15 с мультипортом.
#1039 |
![]() Регистрация: 07.04.2009
Сказал(а) спасибо: 300
Вес репутации: 17 ![]() |
Стабильная работа на 3К. ( Работает без затыков. с au ). /по информации полученной с родственного форума /.
1:
#1040 |
![]() Регистрация: 02.04.2009
Сказал(а) спасибо: 112
Для эмулятора фан-карты данное решение также имеет силу. Кто использует, не обязательно переделывать конфиг под голд. Достаточно добавить фильтр fCommonEMM с привязкой к ридеру фанки, и можно включать автообновление.
Метки |
плагины |
CSC плагин для шаринга | HIM | Плагины/Plugins | 11 | 23.02.2020 17:15 |
Wincsc.dll плагин для шары (настройка.) | HIM | Плагины/Plugins | 4 | 02.07.2016 10:28 |
Плагин для IPTV | paska | Плагины, редакторы и инструкции для Spark | 11 | 24.03.2016 14:56 |
плагин MyTube | sergey99911 | Enigma 2 | 5 | 24.07.2013 22:20 |
Прошивка с mpcs, oscam, wicardd для ASUS RT-N10U, RT-N15U, RT-N16, wl500gp, wl500gpv2, wl500w | max_mad | Прошивка роутеров Asus, D-Link, TP-Link, Acorp...) | 1 | 25.02.2013 23:16 |
