На форуме: 51
Старый 11.09.2013, 20:29   #941
kneht
Ресивер: Amiko 8900 и GI 8120
Сказал(а) спасибо: 15
kneht пока неопределено
rik405 в твоем конфе, прописал свою инфу по серваку, ничего не происходит,
прога при перезапуске плагина с пульта видает такое, и тишина в ответ
20:26:28 192.168.0.104 wicardd: wicardd-sh4 version 1.15 paranoia (Aug 18 2013) http://wicard.tv
20:26:28 192.168.0.104 wicardd: Build options: [AutoConf] [TuxBox SCI] [DVBAPI] [STAPI] [WEBIF] [ExMLog] [TWIN]
20:26:28 192.168.0.104 wicardd: disabling internal CAS - -1
20:26:28 192.168.0.104 dvb: Filter object created.
20:26:28 192.168.0.104 all123: ECM queue size = 32
20:26:28 192.168.0.104 all123: filter(s) used: dvb
20:26:28 192.168.0.104 wicardd: thread 695997640 created
20:26:28 192.168.0.104 all124: ECM queue size = 32
20:26:28 192.168.0.104 all124: filter(s) used: dvb
20:26:28 192.168.0.104 all123: reader thread started async, pid 1395, tid 695997640
20:26:28 192.168.0.104 wicardd: thread 697046216 created
20:26:28 192.168.0.104 all125: ECM queue size = 32
20:26:28 192.168.0.104 all125: filter(s) used: dvb
20:26:28 192.168.0.104 wicardd: thread 698094792 created
20:26:28 192.168.0.104 all2001: ECM queue size = 32
20:26:28 192.168.0.104 all124: reader thread started async, pid 1396, tid 697046216
20:26:28 192.168.0.104 all125: reader thread started async, pid 1397, tid 698094792
20:26:28 192.168.0.104 all2001: filter(s) used: dvb
20:26:28 192.168.0.104 wicardd: thread 699143368 created
20:26:29 192.168.0.104 wicardd: thread 700191944 created
20:26:29 192.168.0.104 all124: ECM queue size = 32
20:26:29 192.168.0.104 all2001: reader thread started async, pid 1398, tid 699143368
20:26:29 192.168.0.104 all123: reader thread started async, pid 1399, tid 700191944
20:26:29 192.168.0.104 all124: filter(s) used: dvb
20:26:29 192.168.0.104 wicardd: thread 701240520 created
20:26:29 192.168.0.104 all125: ECM queue size = 32
20:26:29 192.168.0.104 all125: filter(s) used: dvb
20:26:29 192.168.0.104 all124: reader thread started async, pid 1400, tid 701240520
20:26:29 192.168.0.104 wicardd: thread 702289096 created
20:26:29 192.168.0.104 all2001: ECM queue size = 32
20:26:29 192.168.0.104 all2001: filter(s) used: dvb
20:26:29 192.168.0.104 wicardd: thread 703337672 created
20:26:29 192.168.0.104 all125: reader thread started async, pid 1401, tid 702289096
20:26:29 192.168.0.104 all123: ECM queue size = 32
20:26:29 192.168.0.104 all123: filter(s) used: dvb
20:26:29 192.168.0.104 all2001: reader thread started async, pid 1402, tid 703337672
20:26:29 192.168.0.104 wicardd: thread 704386248 created
20:26:29 192.168.0.104 all123: reader thread started async, pid 1403, tid 704386248
20:26:29 192.168.0.104 wicardd: thread 705434824 created
20:26:29 192.168.0.104 all124: reader thread started async, pid 1404, tid 705434824
20:26:29 192.168.0.104 wicardd: thread 706483400 created
20:26:29 192.168.0.104 wicardd: thread 707531976 created
20:26:29 192.168.0.104 all125: reader thread started async, pid 1405, tid 706483400
20:26:29 192.168.0.104 all2001: reader thread started async, pid 1406, tid 707531976
20:26:29 192.168.0.104 wicardd: thread 708580552 created
20:26:29 192.168.0.104 all123: reader thread started async, pid 1407, tid 708580552
20:26:29 192.168.0.104 wicardd: thread 709629128 created
20:26:29 192.168.0.104 all124: reader thread started async, pid 1408, tid 709629128
20:26:29 192.168.0.104 wicardd: thread 710677704 created
20:26:29 192.168.0.104 all125: reader thread started async, pid 1409, tid 710677704
20:26:29 192.168.0.104 wicardd: thread 711726280 created
20:26:29 192.168.0.104 wicardd: thread 712774856 created
20:26:29 192.168.0.104 all2001: reader thread started async, pid 1410, tid 711726280
20:26:29 192.168.0.104 all123: reader thread started async, pid 1411, tid 712774856
20:26:29 192.168.0.104 wicardd: thread 713823432 created
20:26:30 192.168.0.104 all125: ECM queue size = 32
20:26:30 192.168.0.104 all125: filter(s) used: dvb
20:26:30 192.168.0.104 all124: reader thread started async, pid 1412, tid 713823432
20:26:30 192.168.0.104 wicardd: thread 714872008 created
20:26:30 192.168.0.104 all2001: ECM queue size = 32
20:26:30 192.168.0.104 all2001: filter(s) used: dvb
20:26:30 192.168.0.104 wicardd: thread 715920584 created
20:26:30 192.168.0.104 biss: ECM queue size = 32
20:26:30 192.168.0.104 all125: reader thread started
kneht вне форума   Ответить с цитированием
Старый 11.09.2013, 20:35   #942
rik405
Аватар для rik405
Сказал(а) спасибо: 787
Оставь активным только один ридер с ша..ой и посмотри что будет остальные ридеры отключи. И с ша..ой должен быть только один ридер, пропиши все порты через запятую.
Старый 11.09.2013, 20:51   #943
kneht
оставил один ридер с триколором, остальные порты прописал в строчку,
заработало все.
спасибо ребята выручили, а то два дня над им колдую
Старый 15.09.2013, 11:44   #944
jahoo
jahoo пока неопределено
Как открыть ТНТ на 75E ?
Несколько дней назад его закодировали он состоит в пакете Радуги, но шара от радуги не открывает, была такая ж проблема с СТС но дописал chid и стал показывать
на ТНТ решения не нашел помогите...
jahoo вне форума   Ответить с цитированием
Старый 15.09.2013, 12:58   #945
Krasopet
Аватар для Krasopet
Сказал(а) спасибо: 20
Krasopet скоро придёт к известности
На Ямал 201/300К 90гр остался открытый ТНТ+4
11057 V
26470, 3/4
MPEG-2
Krasopet вне форума   Ответить с цитированием
Старый 15.09.2013, 14:24   #946
skif001
Сказал(а) спасибо: 137
rik405---не будет в твоем конфиге работать триколор
надо так
rule = caid=4AE1;ident=0,11,02;ident:=0;accept
ident:=0---двоеточие пропущено
Старый 16.09.2013, 20:49   #947
rik405
Аватар для rik405
Ребята потух викард 15 сегодня послеобед поскажыте это евление времменное или нада исправлять викард конф зарание большое спасиба за любую информацию .
Что именно потухло???
Старый 16.09.2013, 20:55   #948
oktagon
Аватар для oktagon
Ресивер: GI S8120 HD
Сказал(а) спасибо: 493
Мужики, дайте файл конфигурации на 36 градус пакет НТВ Плюс, НТВ Плюс HD + Триколор + Лыбидь ТВ. Плюнул я на MgCamd, как не бился НТВ Плюс HD не идёт.
Спасибо!!!
Старый 16.09.2013, 20:57   #949
rik405
Аватар для rik405
Сообщение от oktagon Посмотреть сообщение
Спасибо!!!
Вы полистайте странички назад там все и найдете!
Старый 16.09.2013, 21:04   #950
rik405
Аватар для rik405
Перастала работать нтв + екстра и виасат балтик все что работает от нета бисы и трыколор работает извените я новичек и нерозбираюсь сильно как настраевать викард
К шаровику обращались скорее у него проблемы.
Старый 16.09.2013, 21:35   #951
oktagon
Аватар для oktagon
rik405 я их перелистал и перечитал, уже наизусть помню, только то что надо так и не нашёл. Возможно и пропустил где то
Старый 16.09.2013, 22:07   #952
viktor70
Аватар для viktor70
Ресивер: VU+UNO
Сказал(а) спасибо: 40
Поблагодарили 64 раз(а) в 18 сообщениях
viktor70 на пути к лучшему
to oktagon
Примерно так (перезалил исправленый)
Тип файла: rar wicardd.rar 506 байт 242
Последний раз редактировалось viktor70; 16.09.2013 в 23:58.
viktor70 вне форума   Ответить с цитированием
Старый 16.09.2013, 22:44   #953
oktagon
Аватар для oktagon
viktor70, а если портов несколько, как будет выглядеть эта строка
[reader]
active = 0
name = tricolor
type = newcamd525
account = лог:пар@сер:порт:0102030405060708091011121314
debug = 0
reconnect_delay = 10
emm_cache = 1
ecm_ttl = 5000
filter = dvb
Старый 16.09.2013, 23:16   #954
viktor70
Аватар для viktor70
Ресивер: VU+UNO
Несколько портов для tricolor???
Если +++ идут по разным портам HD и SD то добавте еще один [reader] с нужным вторым портом...
А если про "мультипорт" то примерно так: (ток не знаю пойдет ли на 8120, на UNO идет)
[reader]
active = 1
name = SHARA
type = newcamd525
account = лог:пар@сервер
multiport = 3001,3002,3003,3004,3005,3007,3008,3010,3018,3037, 3049,2001
debug = 0
emm_cache = 1
ecm_ttl = 5000
filter = dvb
Тип файла: rar wicardd.rar 512 байт 209
Последний раз редактировалось viktor70; 16.09.2013 в 23:55.
Старый 17.09.2013, 10:39   #955
oktagon
Аватар для oktagon
viktor70 спасибо огромное, всё заработало MgCamd и рядом не стоит с wicardd
Старый 18.09.2013, 19:30   #956
VadimLA
Ресивер: vu+ uno
VadimLA на пути к лучшему
Хотел спросить может здесь мне помогут. Я пытаюсь настроить wicard но пока не особо получается. Нужно следующее офф карта Лыбидь в нижнем CI слоте и тетя шура на остальные каналы. Получаеться только шура или только карта или шура пока не стану на канал Лыбидь потом шура не работает. Вобще по всякому но только не так как хочеться. Заранее благодарен за конфиг.
VadimLA вне форума   Ответить с цитированием
Старый 18.09.2013, 22:26   #957
Сообщение от VadimLA Посмотреть сообщение
Хкарта Лыбидь в нижнем CI слоте
как бы в CI слот устанавливается CI модуль. а в амико (даже триплексе) CI нету.
Старый 18.09.2013, 22:29   #958
Немогу настроить парнушку на хотберте вот так прописываю в викард конфи rule = caid=0500;ident=023100,032500,041700,042200,042300 ,042700,042800,040810,042400,043800,032830,024F00, 024700,023800,020A00;accept #all viaccess а она не запускается подскажить
может нужно подписку купить еще?
а вообще в вашем фильтре до х... очень много масла.
половина идентов дохлые.
мне встречалась такая строка
Код:
rule = caid=0500;ident=042300,041700,043800,042700,032500,023100,024700,042200;accept # other
Старый 19.09.2013, 00:04   #959
VadimLA
Ресивер: vu+ uno
Нету никто и не спорит. А хорошо бы конфиг придумать для ресивера в котором есть.
Старый 19.09.2013, 15:51   #960
а вы не пробовали использовать mcas?
тяжело придумывать не имея железки под рукой.
правда CI есть?
не поверю пока фото не увижу
Метки
плагины
Текущее время: 21:51. Часовой пояс GMT +3.
