На форуме: 20
Вернуться   Форум VolSat > Спутниковые ресиверы > Enigma 2 Linux Based Receivers > Dreambox HD > Софт для DreamBox HD
Софт для DreamBox HD БЕЗ ОБСУЖДЕНИЯ!
Старый 11.01.2016, 23:01   #181
halfhalf
Ресивер: dreambox
Поблагодарили 118 раз(а) в 105 сообщениях
halfhalf на пути к лучшему
BlackHole.2.1.7.WilCard.DM800HD.CLONE.SSL84D.SIM2. OE2.0.bymarwen.09.01.2016
09/01/2016: * New skin_default: Darkstar
- Support Ecminfo for Emu Wicardd
* Blackhole font size is Skinnable
- ADD Current Value
* BlackholeAddons updated:
- ADD Reload Setting (Reload Channel Lists)
- Now BlackholeAddons is in MainMenu (Menu-BlackholeAddons)
BlackHole.2.1.7.WilCard DM800HD CLONE
DREAMBOX ALL IMAGES 2014 - 2015
halfhalf вне форума   Ответить с цитированием
Старый 23.01.2016, 18:49   #182
halfhalf
Ресивер: dreambox
OpenPLi.4.0.NewGstreamer1.7.1.DM800HD.CLONE.SSL84D .SIM2.OE2.0.06.01.2016
Changes since previous release:
- Gstreamer snapshot updated to 1.7.1:
* The mp4 issue when playing from remote locations has been fixed upstream,
so I've dropped the revert.
* Libsoup has been updated so I've dropped the revert for the
old libsoup as well.
- DM800Se V2 and DM500HD V2 kernel config has been
cleaned and more in sync with PLi's config for the other Dreambox models.
- More free space by adding a task before do_package_write_ipk which will upx compress some binaries.
* This should give us a few more MBs to work with (Dreambox *cough*).
- Major rework of the meta-fulan BSP for spark thanks to Tapaat for helping me out.
* Now using Tapaat's drivers which fixes the frambuffer (and 22khz?) issue.
* Enable of the zram module.
* Shipping his wifi drivers.
* VFD time is now synced every 5 minutes using a cron job.
* Software update and plugin-installation has been fixed.
* Using Tapaat's lirc config for spark and spark7162.
- The usual batch of dvbmediasink fixes by Christophecvr and mx3L:
* A brand new divx/xvid bitstream unpacker by mx3L should fix playback of avi files with wrong fourcc.
- Libsoup has been updated to 2.52 (from master-next).
- Refactor wifi drivers a bit on Linux 2.6.18,
not auto-loading the mt7600 anymore,
the correct driver should hopefully be loaded
when you plugin your wifi stick.
Changes compared to openpli-oe-core gst-1:
- Ships with gstreamer upstream master git:
Using the same patches as openpli-oe-core gst-1 with only these changes:
Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
because this patch was already checked in upstream.
- Every receiver uses christophecvr's multibox dvbmediasink.
- Using libtrmp and rtmpdump from oe-alliance.
- Some small enigma2 patches for Dreambox receivers
(ac3/dts bypass and blanking on zap support).
These are only applied for Dreambox receivers.
- AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
- IPTV Player from samsamsam included (thx to Athoik for the recipe).
- Large list of public IPTV streams included thanks to the Japhar Team.
- Updated libcdio and cdtextinfo for audio-cd support by christophecvr.
- DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
added si2166b blindscan support.
- Using aio-grab source from oe-alliance which includes fixes for spark receivers.
Known issues:
- DM800 first boot will take a while, please be patient. The next boot will be faster.
- On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
Please use 'duckbox' instead.
- On Zgemma Star you cannot use full HD skins.
This is a hardware/driver limitation.
Please don't try it, it will crash enigma2.
- Some Dreambox remotes may behave very sensitive.
This causes button presses to register multiple times instead of just once.
As a workaround you can adjust the key interval:
Go to: Menu - System - Input devices - dreambox remote control (native).
Set "Change repeat and delay settings" to yes
Set "Interval between keys when repeating:" to 200ms or 300ms.
Press green button (OK)
Now set the same delay for: "dreambox advanced remote control (native)" as well.
TODO:
- Linux 2.6.18: Create a plugin / ppanel to select which Realtek/Ralink driver to
load on startup (eg. rt3070, rt55xx, mt7600), since they cannot be loaded at the same time.
- Linux 2.6.18: Look into the v4l usb drivers.
- Add Spark specific plugins by gorski.
- Add meta-ini from OE-Alliance and shape it up for openpli-oe-core.
OpenPLi.4.0.NewGstreamer1.7.1 DM800HD CLONE
Старый 23.01.2016, 19:03   #183
halfhalf
Ресивер: dreambox
BlackHole.2.1.7.NewFix.DM800HD.CLONE.SSL84D.SIM2.O E2.0.bymarwen.21.01.2016
21/01/2016: * New Enigma2 Compiled
* Allow gstreamer to convert the audio when the dvbaudiosink doesn't
support the format
* servicemp3:
- follow GstBuffer API changes
- follow gstreamer api changes
- fix gstreamer assertions, iterating elements
- add sanitychecks on subtitle caps
- fix getting text-tags
- support text/x-raw subtitle caps
* servicedvb: allow timeshift to be started on an http ts stream
* Export timeshift helper functions
* channelselection:
From setup menu in channelselection go back to channelselection.
So you can toggle channelselectioncontextmenuCustomise
and configchannelselection
* Fix crash when writing epg cache to the disk:
Timestamp in contentTimeMap can differ from eventData timestamp.
In such cases eventData is not removed from timeMap. timeMap is
used in eEPGCache::save which accesses in such a case freed memory.
This can cause crash.
BlackHole.2.1.7.NewFix DM800HD CLONE
Старый 20.06.2016, 23:55   #184
halfhalf
Ресивер: dreambox
BlackHole.3.0.2C.DM800HD.CLONE.SSL84D.SIM2.OE2.0.b ymarwen.15.06.2016
15/06/2016: * StartWizard:Remove Parental Control from wizard
* Fix Mounting HDD and usb
* Add New arabic translation(ar.po)
* Fix Some Bugs(you can Now Test IptvPlayer)
BlackHole.3.0.2C DM800HD CLONE
Старый 15.02.2018, 14:56   #185
gonzales67
Ресивер: 800hd
gonzales67 пока неопределено
Сообщение от halfhalf Посмотреть сообщение
они могут иметь новую ссылку
gonzales67 вне форума   Ответить с цитированием
Старый 15.02.2018, 15:33   #186
gonzales67
Ресивер: 800hd
Файл не найден. Возможно он был удален.
Старый 15.02.2018, 18:51   #187
halfhalf
Ресивер: dreambox
Сообщение от gonzales67 Посмотреть сообщение
try your
https://turbobit.net/juceuvh4y15r.html
Старый 17.02.2018, 13:21   #188
gonzales67
Ресивер: 800hd
nou BlackHole.3.0.2.
I need
OpenPli.4.0.Hdglass16.9.12.DM800HD.SIM2.OE2.0.SSL8 4D.byHouara.17.12.2014.Clone
DM800HD SE (original)+DIR-320+Tiger T600HD bonshura Dreambox HD 4 20.05.2018 23:52
Зависает DM800HD. DVB S плата, спайка 2 ножек как у Вас? BAV2102 Dreambox HD 1 27.02.2015 08:43
Текущее время: 08:24. Часовой пояс GMT +3.
