На форуме: 47
Вернуться   Форум VolSat > Спутниковые ресиверы > Enigma 2 Linux Based Receivers > Dreambox HD > Софт для DreamBox HD
Софт для DreamBox HD БЕЗ ОБСУЖДЕНИЯ!
Старый 10.11.2014, 20:20   #81
halfhalf
Ресивер: dreambox
Поблагодарили 118 раз(а) в 105 сообщениях
halfhalf на пути к лучшему
halfhalf вне форума   Ответить с цитированием
Старый 13.11.2014, 02:38   #82
halfhalf
Ресивер: dreambox
ruDREAM3.0.DM800HD.SIM2.OE2.0.SSL84D.byHouara.11.1 1.2014.Clone
-converted from DM800se to DM800
-Patched to DM800 Boxes
-Patched Time limited for watching channels
-Added last drivers 20131228
-Added last version my modded OpenWbif
-fixed WLAN Connection
-Edit Python math to make image full compatible with DM800HD
About Emus How to
1-Form attach download and install emu
2-After installed:
*Blue button
*Select Emu and press OK buttin
About Change emu panel style How to
Exit button
settings
TV
Customize TV
Setup of CAMD profile select mode (simply or expert)
About Hid update check info How to
Exit button
Settings
Software
Settings packages management
check for update = off
About Restart shell (enigma2) How to appear it
Exit button
settings
system
customize system
setup mode = Expert
About remote control How to adjustment
Exit button
settings
system
input device
press ok to dreambox remote control (native) and adjustment as you like ..
Warningon't Make Update Online
In this link you can Download 2 skins for Image
In this link you can Download some plugins for Image
From here you can download my modified DD_Subtiteplayer V2.39 for ruDREAM image only
opkg install -force-overwrite /tmp/*.ipk
PLUGINS SKINS PICONS SUB CLICK LINK
ruDREAM3.0.DM800HD ALTERNATIF 1 CLICK LINK
ruDREAM3.0.DM800HD ALTERNATIF 2 CLICK LINK
OTHER NEW IMAGES CLICK LINK
SEPTEMBER 2014 DREAMBOX IMAGES
OTHER OLD IMAGES CLICK LINK
Старый 13.11.2014, 21:30   #83
halfhalf
Ресивер: dreambox
Старый 14.11.2014, 18:46   #84
halfhalf
Ресивер: dreambox
BlackHole2.1.3.DM800HD.SIM2.OE2.0.SSL84D.byHouara. 14.11.2014.Clone
MeoBoot updated and now compatible with all major images
New Army skin DarkSky
New fade effect in osd
OpenWebIf updated and added Italian translation
Httpstream updated:
- added chunked transfer support.
- connect to TS stream in seperate thread.
- add basic http authentication support.
- add redirect and playlist support.
Elistbox: add setFont function (workaround for Full Hd skins)
media-tree rebuilded module list
opkg install /tmp/*.ipk
BlackHole2.1.3.DM800HD CLICK LINK
Старый 15.11.2014, 22:00   #85
halfhalf
Ресивер: dreambox
Blackhole2.1.3.Genuine.DM800HD.SIM2.OE2.0.SSL84D.b yRAED.13.11.2014.Clone
Httpstream updated:
enigma2-plugin-extensions-tspanel_7.3_mips32el.zip
install
Blackhole2.1.3.Genuine.DM800HD byRAED CLICK LINK
Blackhole2.1.3.HD_X1.DM800HD.SIM2.OE2.0.SSL84D.byH ouara.14.11.2014.Clone
Blackhole2.1.3.HD_X1.DM800HD CLICK LINK
Старый 17.11.2014, 20:04   #86
halfhalf
Ресивер: dreambox
BlackHole2.1.3.Doscam.CCcam.Mgcamd.OE.2.0.SIM2.DM8 00HD.SSL84D.17112014.byMarwen.Clone
*bootloader: ssl84d
*New Fix Teleportation by raed
*New bootlogo
*New po arabic language
*Teletext patched and tested
*Positionersetup Patched
*EMU: CCcam2.2.1 ;Mgcamd1.38C;Doscam0.23 TNTsat autoupdate
*New keymap.xml Mod almwad3:
-record with red button
-timeshift with yellow button
*plugin nstreamplayer updated
*Extra Plugins (You Install)
-Wicard plugin
-Tspanel 7.3 Plugin
-DD_Subtitle-Player
-Extrachannelselection_for_blackhole_2.6
or
BLACKHOLE2.1.3 CCCAM and DOSCAM
BLACKHOLE2.1.3 CCCAM and DOSCAM CLICK LINK
BLACKHOLE2.1.3 MGCAMD and DOSCAM
BLACKHOLE2.1.3 MGCAMD and DOSCAM CLICK LINK
Старый 17.11.2014, 20:47   #87
berimor
Сказал(а) спасибо: 421
halfhalf---- привет есть к тебе вопрос ---- а ти все ети имиджи(бекапи) проверяеш перед тем как с соседнего сайта тирить и сюда викладивать
Старый 17.11.2014, 22:35   #88
rik405
Аватар для rik405
Сказал(а) спасибо: 787
Уважаемый berimor практически все имиджи рабочие. Что плохого что он размещает ссылки на эти имиджи для нашего форума?
Старый 17.11.2014, 23:11   #89
berimor
да пускай размещает ссилки но стаким ускорением --- я считаю чтоб шото размещать на форуме надо сначала проверить работает имидж или бекап и т.д. Я сам лично занимаюсь проф.енигмой 7 лет и никогда так неставил на тюнера по несколько раз на день ставил разние имиджи и вот задал вопрос.
Да неспорю можна ставить и сто раз имиджи на день но в каждих имиджах и бекапах есть разние проблеми ----- в силе ему ответить на все вопроси - думаю что нет
Старый 17.11.2014, 23:21   #90
topol9
Аватар для topol9
зема!!! не успеваем одну протестировать,как уже другая выложена. нет времени даже передохнуть!! да и до жены никак руки не доходят. одни имиджи на повестке дня
Старый 19.11.2014, 02:49   #91
halfhalf
Ресивер: dreambox
OpenPli3.0.HDglass16_9.03.DM800HD.SIM2.OE2.0.SSL84 D.byHouara.17.11.2014.Clone
*HDglass16_9.03 Skin
OpenPli3.0.HDglass16_9.03 CLICK LINK
Старый 23.11.2014, 21:11   #92
halfhalf
Ресивер: dreambox
BlackHole2.1.3.Doscam.CCcam.Mgcamd.OE.2.0.SIM2.DM8 00HD.SSL84D.23112014.byMarwen.Clone
*New bootlogo
*Fixed Arabic Epg Language
*Add Patch Teleportation V2.1
*Skin.xml:Fixed screen Reorder Plugin List
17/11/2014:
*bootloader: ssl84d
*New bootlogo
*EMU:CCcam2.2.1 ;Mgcamd1.38C;Doscam0.23 TNTsat autoupdate
or
BLACKHOLE2.1.3 CCCAM2.2.1 and DOSCAM023
BLACKHOLE2.1.3 CCCAM2.2.1 and DOSCAM023 CLICK LINK
BLACKHOLE2.1.3 MGCAMD1.38C and DOSCAM023
BLACKHOLE2.1.3 MGCAMD1.38C and DOSCAM023 CLICK LINK
Последний раз редактировалось halfhalf; 23.11.2014 в 22:08.
Старый 24.11.2014, 21:21   #93
halfhalf
Ресивер: dreambox
OpenPli3.0.DarkSkyHD.DM800HD.SIM2.OE2.0.SSL84D.byH ouara.24.11.2014.Clone
* TSPanel 7.4
* DarkSky HD
* PluginMover
OpenPli3.0.DarkSkyHD.DM800HD CLICK LINK
OpenPli3.0 Noplugin DM800HD
OpenPli3.0 Noplugin DM800HD CLICK LINK
Старый 28.11.2014, 02:03   #94
halfhalf
Ресивер: dreambox
OpenATV4.2.MetropolisHD.DM800HD.SIM2.OE2.0.SSL84D. byHouara.27.11.2014.Clone
* OpenATV Latest Version
* MetrolpolisHD Skin
* TNT OK
OpenATV4.2.MetropolisHD.DM800HD CLICK LINK
Старый 28.11.2014, 16:13   #95
halfhalf
Ресивер: dreambox
BlackHole2.1.3.Update.DM800HD.SIM2.OE2.0.SSL84D.by Marwen.27.11.2014.Clone
* New Plugin Blackhole Addons (Blackhole Cams)
* Now you can Download All Cams
* Patch Freesat Epg Data
23/11/2014:
* New bootlogo
* Fixed Arabic Epg Language
* Add Patch Teleportation V2.1
* Skin.xml:Fixed screen Reorder Plugin List
BlackHole2.1.3.Update.DM800HD CLICK LINK
BlackHole2.1.3.Update.DM800HD ALTERNATIF CLICK LINK
Старый 29.11.2014, 19:37   #96
halfhalf
Ресивер: dreambox
Старый 01.12.2014, 00:15   #97
halfhalf
Ресивер: dreambox
BlackHole2.1.3.New.Update.DM800HD.SIM2.OE2.0.SSL84 D.byMarwen.30.11.2014.Clone
* Original Blackhole Teleportation
*Extra Plugins You Install
-Wicard plugin
-NEW Tspanel 7.4 Plugin
-DD_Subtitle-Player
or
28/11/2014:
* New Plugin Blackhole Addons Mod Marwen (Blackhole Cams)
23/11/2014:
* New bootlogo
BlackHole2.1.3 New Update DM800HD CLICK LINK
OCTOBER 2014 DREAMBOX IMAGES CLICK LINK
SEPTEMBER 2014 DREAMBOX IMAGES CLICK LINK
Старый 01.12.2014, 20:59   #98
halfhalf
Ресивер: dreambox
VTI.8.0.0.DM800HD.SIM2.OE2.0.SSL84D.byHouara.01.12 .2014.Clone
With modular, flexible VTi Skin: Atile HD
VTi Bootlogos and Radiomode Logo.
Short press on blue button opens VTi Panel, long press opens Pluginmenu
Support for FTDI chipset cardreader like smargo and easymouse2
Running Softcam shown in the Infobar
MovieList with extended functions
Support for full image backup and restore
Supports VTi image flash online
Restore Plugins, Bouquets, Settings, etc. during installation
Remove preinstalled packages during installation
-I have converted and patched VTI (VU+) Image to Dreambox
-Edited opkg feed
-Fixed WLAN Connection
-Edit Python files to make image full compatible with DM800HD
-Front screen (Not fixed yet)
About remote control How to adjustment >>
menu
setup
system
input device
How to Download Cams and Active it:
1-Blue button > Blue button (Cam Center) > Blue button (Manage Cams)
2-Then select and download what you need
3-To active cam press Blue button > Blue button (Cam Center)
4-Select Cam and press Green button (Start Cam)
VTI.8.0.0 DM800HD CLICK LINK
OTHER NEW 2014 END IMAGES CLICK LINK
Старый 04.12.2014, 02:38   #99
halfhalf
Ресивер: dreambox
OpenVIX.Apollo.095.DM800HD.SIM2.OE2.0.SSL84D.byHou ara.03.12.2014.Clone
OpenVIX.Apollo.095 DM800HD CLICK LINK
Старый 05.12.2014, 20:37   #100
halfhalf
Ресивер: dreambox
Satdreamgr3.0.DM800HD.SIM2.OE2.0.SSL84D.byHouara.0 4.12.2014.Clone
Satdreamgr3.0 DM800HD CLICK LINK
DM800HD SE (original)+DIR-320+Tiger T600HD bonshura Dreambox HD 4 20.05.2018 23:52
Зависает DM800HD. DVB S плата, спайка 2 ножек как у Вас? BAV2102 Dreambox HD 1 27.02.2015 08:43
Текущее время: 16:50. Часовой пояс GMT +3.
