Тем: 4,640, Сообщений: 359,819, Пользователи: 159,609
На форуме: 19
Старый 08.05.2009, 10:39   #1
Вес репутации: 78
По умолчанию Dr.HD F16
TM-6900 HD USB-PVR Combo
» High Definition Satellite & High Definition Terrestrial + 10,000 Channels + USB 2.0 with: PVR Ready for Timeshift, Record & Playback of Channels, MP3/JPEG & Software Download + 1 Card Reader + 2 Common Interface (2CI) + HDMI & Component with Upscaler + Do
* 2 High Definition Tuners: DVB-S/DVB-S2 Satellite & DVB-T Terrestrial Compliant (MPEG-II/ MPEG-IV/ H.264)
* Output Resolution: 576p & 576i, 720p & 1080i
* 1 Smart Card Reader & 2 Common Interfaces (2CI)
* HDMI & Component Output (YPbPr) with Upscaler to Improve Picture Quality
* 10,000 TV & Radio Channels
* USB2.0 PVR Ready via external HDD or USB Flash Drive (memory stick) with Timeshift, Record & Playback functions
* MP3 player and JPEG viewer via external HDD or USB Flash Drive (memory stick)
* Software & Channel List download via USB 2.0
* Fully Featured VFD text Front Panel Display
* Sensitive Tuner
* Less than 1 second channel change
* Dolby Digital Optical S/PDIF
* DiSEqC 1.0, 1.1, 1.2 & 1.3 (USALS) compatible
* Auto Navigation system – select as many satellites as you want to search
* On-screen display with true full color resolution
* Enhanced 16 Favorite channel groups
* Channel control by: Favorites, Lock, Skip, Move & Delete
* Channel sort by: All, Alphabet, Transponder & CAS
* Multilingual OSD Menu: English, Spanish, Portuguese, French, Dutch, German, Italian, Turkish, Arabic, Russian, Persian
* Extended EPG and program reservation on EPG
* Teletext & Subtitle by OSD and VBI
* Last channel memory function
* Factory default channel list
* Various games
* Software & channel list upgrade via RS-232C: PC to STB, STB to PC, STB-STB and USB
* Parental, Installation & Receiver Lock
* Zoom function on Pause & Live channel
* Multipicture display
* Support for multiple language broadcasts
* SCPC & MCPC receivable from C/Ku band satellites LNBs supported: Universal, Single, Single S & C band wideband LNBs
* Multi TV Standards supported: PAL G, I, K, M & NTSC M with 4:3 & 16:9 Screen Formats
* 90-250V AC 50/60 Hz
* LNB Short Circuit protection onboard
* 2 Scarts, (RGB, CVBS) & S-Video
Кроме внешнего вида и другого меню совпадают во всем. Программа загрузки, редактирования каналов, коды эму и ш.ры. Ресивер 2007 года для Англии, регулярно выходят прошивки, после изменения ID производителя в прошивке без проблем заливается в F16. Минус в том , что пульт у них с перемычками и настраивается на разные модели. Поэтому пульт без перенастройки не работает с английскими прошивками и на морде лица русские названия каналов превращаются типа в корейские, в меню русский остается.
Dr.HD F16
Цена: 350.00 у.е.
До сих пор – всем было понятно, что максимум функций – в аппаратах с операционной системой Linux. И при ОЧЕНЬ грамотном подходе (и наличии очень грамотного пользователя) такие ресиверы действительно способны на многое.
Но что делать тем, кто просто хочет настроить и пользоваться? И не хочет несколько месяцев разбираться и обучаться, чтобы справится с подобными аппаратами?
Ресивер Dr.HD F16 - уникален по своим возможностям не только для рынка России, но и для мирового. Фактически – это наиболее универсальный аппарат из всех универсальных пользовательских аппаратов. Всё очень просто в настройках, и при этом максимально функционально.
Во-первых, Dr.HD F16 является как спутниковым, так и эфирным цифровым ресивером, что весьма актуально при нынешних разговорах о запуске подобного федерального вещания в MPEG-4 (не только в столице, но и во всех регионах). Причём в ряде регионов России DVB-T уже запущено, в некоторых – запускается, но очевидно одно: за счет наличия MPEG-4 AVC H.264 данный ресивер уже совместим с этим вещанием.
Во-вторых, обеспечена максимально возможная совместимость с официальными картами (в том числе, без CAMов, а при помощи встроенных картоприемников). Это касается и карт на Viaccess, и карт в кодировке Irdeto. В своё время некоторые ресиверы (типа легендарного «9500») – прославились скоростью переключения каналов в «Via». Такая же поразительная скорость переключения есть и в данном “F16”. (И не надо покупать модуль!)
В-третьих, в аппарате в некоторых софтах есть возможность подключения к интернету как напрямую через Ethernet LAN, так и опосредованно через компьютер (RS-232). Раньше такая универсальность являлась основной причиной покупки простыми пользователями аппаратов с операционкой Linux, ведь других вариантов и не было. А в Dr.HD F16 – имеем крайне простое и функциональное решение.
В-четвертых, дополнительные функции, типа наличия в некоторых софтах возможностей открывать не только FTA-каналы.
В-пятых, корректная работа с модулями, в частности Platforma HD и Tricolor (включая новую его модификацию с MPEG-4).
В-шестых, продавец или установщик спокойно может на usb-флешку слить список каналов, новый «софт», приехать к клиенту и установить все настройки за минуту без всякого сканирования и компьютера. Изменился список каналов? Нет проблем. Надо поменять софт и сохранить список каналов? Не проблема. Хотите занести текущий список каналов в установки по умолчанию? Тоже без вопросов. Оцените удобство.
В-седьмых, без дополнительных приборов – теперь вы можете настроить любую антенну, включая «полярку» на мотоподвесе, вообще без индикатора уровня. Потому что в меню уже встроен СПЕКТРОАНАЛИЗАТОР с отличной скоростью и функциональностью работы. Также прямо в спектроанализаторе можно посмотреть совпали ли частоты с теми что в памяти ресивера, а на наиболее популярных спутниках – активируется функция автоопределения спутника, на котором вы находитесь.
В-восьмых, это один из немногих ресиверов, которые реально защищены от короткого замыкания в кабеле (и для желающих мы можем сделать соответствующую демонстрацию!)
В-девятых (не по важности, а просто так сложилось), конечно же, стоит упомянуть что это полнофункциональный PVR-ресивер – к нему и по USB и по eSATA можно подключить внешний «винт» необходимой вам емкости.
Вывод прост: подобного пользовательского аппарата на рынке России до появления F16 - просто не существовало! Dr. HD F-16 – не просто перенял название от истребителя. У него и возможностей тоже с избытком. Настоящий хищник на рынке спутниковых и эфирных ресиверов!
Конфигурация ресивера:
Удобство эксплуатации (меню, пульт) Очень хорошее
2 тюнера Нет
PIP Нет
Модулятор Нет
RCA-композит (тюльпаны) Есть
SCART 2
S-video Есть
Компонентный выход Есть отдельный через тюльпаны
Качество компонента Отличное
Цифровой аудиовыход Оптический
USB 2.0 Есть
Ethernet Есть
0/12 V Нет
Индикатор Есть
Размер памяти (каналов) 5000
EPG на неделю Есть
Субтитры Есть
Встроенные игры Нет
Рус. меню Есть
Русская инструкция Есть
Цвет Чёрный
Доп. функции ресивера с HDD
Наличие установленного жёсткого диска Можно установить
Размер установленного жёсткого диска Нет
Какой диск можно установить SATA
Допустимый размер диска 1 Tb
Рекомендованные производители HDD Seagate и Western Digital
Возможность записи одного канала и просмотра второго Нет
Запись 2 каналов одновременно Нет
Time Shifting Есть
MP3 decoding Есть
Под Hi-Fi стойку Нет
Wi-Fi Нет
Способ подключения жёсткого диска Установка в корпус ресивера
Работа с картами и недокументированные функции
Картоприёмник на Viaccess Можно если установить Cam-модуль
Картоприёмник на Irdeto Можно если установить Cam-модуль
Картоприёмник на Conax Можно если установить Cam-модуль
Количество разъёмов под модули (CI) 2
Картоприёмник Allcam/MultiCAS (нелиценз.) Есть
Эмулятор Есть
Качество поддержки эмулятора Хорошее
Шара (где это разрешено) Есть через Ethernet
Источник www.wizardfox.net
Старый 19.05.2009, 15:53   #2
Вес репутации: 78
отзыв пользователя:
Сообщение от dvd54
890-й - качественный, после многочисленных обновлений рес
шарит все, включая HD
Замеченные особенности- ОБЯЗАТЕЛЬНО смотрите ESATA на задней панели
Не все винты работают. На комп записи льютя через.....ж
В итого - более менее "отшлифованная" модель
F16. DR HD
Рес с большим потенциалом, пока не все реализовано.
Запись на рес и воспроизведение MP3 - COOL
В итого - для шар... - 890. для экспериментов, записи, и пр... -F16
потенциал больше у последнего
и в догонку неплохая статья: "ОБЗОР ЦИФРОВОГО СПУТНИКОВОГО РЕСИВЕРА DR.HD F-16."
Старый 19.05.2009, 16:16   #3
Вес репутации: 78
По умолчанию Инструкции и документации для Dr.HD F16
Инструкция на Русском для Dr.HD F16
Тип файла: rar Manual_Dr._HD_F16.rar 1.77 Мб 172
Старый 19.05.2009, 16:21   #4
Вес репутации: 78
По умолчанию Редакторы, загрузчики и прочий софт для для Dr.HD F16
Редактор каналов
Поддерживается русский язык в названиях каналов
Тип файла: zip NDFEdit_162.zip 247.6 Кб 73
Старый 19.05.2009, 16:21   #5
Вес репутации: 78
поправленный расшаривальщик папок для винды
Тип файла: zip STBDaemon_102.zip 120.2 Кб 41
Старый 19.05.2009, 16:24   #6
Вес репутации: 78
По умолчанию STBTool.zip
загрузчик по, каналов, ключей....
Тип файла: zip 2009-01-31_4_STBTool.zip 185.6 Кб 70
Старый 19.05.2009, 16:23   #7
Вес репутации: 78
По умолчанию Востановление Dr.HD F16
Boot-файл, может пригодиться для восстановления неудачно прошитых ресиверов
Тип файла: zip boot_HTM8000_7109.zip 155.5 Кб 72
Старый 28.08.2009, 08:44   #8
Вес репутации: 78
По умолчанию Сброс данных при восстановлении реса
Тип файла: zip db_eraser.zip 195 байт 33
Старый 19.05.2009, 16:26   #9
Вес репутации: 78
По умолчанию Ключи для Dr.HD F16
Актуальные ключи
Тип файла: rar keys_20090123-113836.rar 3.0 Кб 81
Старый 20.11.2009, 19:52   #10
NEW CORE with TS MULTIDECODING:
- загрузка и выгрузка BISS ключей в текстовый файл с расширением .KEY
- расширенная инфа статуса соединения в меню внешних карт
- прочие незначительные поправки.
Тип файла: zip F16_201p.zip 4.15 Мб 34
Старый 18.12.2009, 23:19   #11
Sereqa
Аватар для Sereqa
Вес репутации: 34
Sereqa на пути к лучшему
По умолчанию Dr.HD F-16
Цифровой спутниковый HDTV ресивер Dr.HD F-16
Цифровой спутниковый HDTV ресивер Dr.HD F-16 предназначен для приёма эфирных (DVB-T), спутниковых(DVB-S), а также HDTV(высокой четкости) каналов. Функциональность аппарата соответствует самым требовательным запросам, соответствуя ресиверам Hi-End-класса. Ресивер Dr.HD F-16 оснащен 2-мя CI-слотами, универсальным интерфейсом UniCAS, 2-мя USB-разъемами и и разъемом для высокоскоростных жестких дисков eSATA. Также Dr.HD F-16 имеет встроенный Lan- и Com-порты. Реализована возможность фильтрации по CAID вручную для всех каналов и для каждого по необходимости. Выходы: компонентные, HDMI, S-Video. Возможность использования ресивера как медиа-плеера.
Встроенный SatFinder позволяет максимально упростить настройку на необходимый спутник. Работа с протоколами DiCEqC 1.0, 1.1, 1.2, USALS производится корректно и интуитивно понятно.
Максимально упрощена задача загрузки и выгрузки ПО, списка каналов и ключей флеш-носителем через USB-разъем. Возможна загрузка программного обеспечение непосредственно с сайта поставщика без использования ПК.
Характеристики Dr.HD F-16:
· 32-разрядный 266МГц
· DDR SDRAM: 32Мбайт*4
· Flash: 8 Мбайт
· EEPROM: 256 кбит
· USB 2.0
· возможность записи программ на USB-носители и e-SATA винчестеры размером до 1 Tb
· встроенный модуль условного доступа CONAX
· два слота для установки САМ-модулей (Common Interface)
· один тюнер DVB-S/DVB-S2 с петевым выходом и один тюнер DVB-T с петлевым выходом
· 5000 программируемых ТВ и радиоканалов
· быстрый поиск каналов на 1000 транспондерах
· слепой поиск каналов
· удобная система автоматического поиска программ
· функция редактирования PID
· цифровой оптический аудио выход с поддержкой Dolby Digital
· полная совместимость с форматом MPEG2/DVB-S, MPEG4/DVB-S2, H.264
· поддерживаемая символьная скорость в DVB-S: 2 - 45 Msps
· поддерживаемая символьная скорость в DVB-S2: 10 - 30Msps (QPSK), 10 - 30Msps (8PSK)
· корректная работа в C/Ku диапазонах
· меню на 12 языках
· телетекст в формате OSD или VBI
· электронный путеводитель по программам EPG на неделю
· 16 фаворитных списков каналов
· RS232C: скорость передачи данных 115,200 bps / 9 pin D-sub
· возможность установки 20 таймеров
· система цветного телевидения PAL
· поддерживаемое разрешение 1920х1080i, 1280х720p, 720x576i/p
· форматы изображения 4:3. 16:9
· поддержка DiSEqC 1.0/1.1/1.2/USALS
· сеть переменного тока 100-250В, 50/60 Гц
· потребляемая мощность 40Вт
· компонентный выход (YPbPr): 3 RCA Cinch
· TV SCART: выход (CBVS, RGB, Audio R/L)
· VCR SCART: выход (CBVS, RGB, Audio R/L)
· VIDEO OUT (видео выход): 1 RCA Cinch
· AUDIO OUT (аудио выход): 2 RCA Cinch
· HDMI OUT
· S-Video OUT
· Ethernet порт RJ-45
· Размеры: 335х58.5х247 мм
· Вес 3 кг.
· Цвет черный
Тип файла: gif Dr-HD-F-16.gif 7.1 Кб 23
Старый 09.01.2010, 19:27   #12
gurasik431
Аватар для gurasik431
gurasik431 очень-очень хороший человекgurasik431 очень-очень хороший человекgurasik431 очень-очень хороший человекgurasik431 очень-очень хороший человек
s/w f16_207p
прямо с потока теперь выводится служебная инфа:
1.позиция спутника
2.параметры транспондера
3.параметры модуляции
4.видео и аудио кодеки
5.название спутника вместо слова спутник
DNS в STATIC IP MODE отключен
Тип файла: zip F16_207p.zip 4.37 Мб 44
Старый 12.07.2010, 12:25   #13
chersasha1
Аватар для chersasha1
Ресивер: OpenBox S8 PVR
chersasha1 пока неопределено
Добавлена регулировка шага частоты при слепом поиске. Для ускорения поиска используйте шаг 16 или даже 32. За счет пропуска транспондеров с низким SR общее время поиска будет гораздо короче. Полоса TP с SR=27500 около 40М , поэтому для экономии времени спутники популярных провайдеров лучше сканить с шагом 16 или 32. Например, при установке шага 16 все каналы плюсов, триколора и поверхности будут найдены ВСЛЕПУЮ за время около 3-х минут!!!!!!
- Кардинально изменили управление Повороткой в режиме Спектр. Теперь размер шага поворота используется из меню управления Diseqc 1.2, причем, при кратковременном нажатии происходит пошаговое движение, а если кнопку влево-вправо удерживать, мотор переходит в режим непрерывного движения. Остановка происходит в момент отпускания кнопки.
- Вернули функцию "Проверка на Залочку" всех транспондеров в окне спектра, запускается и останавливается желтой кнопкой.
- Поправлена трабла со звуковой дорожкой, на немых каналах приходилось или пересканировать транспондер заново или вызывать меню и потом выход.
- Эксперимент по выравниванию уровня звука долби и обычного. Если плохо, то возвратим на вариант как в 223.
http://drhd.legion.name/drhd_f16_kor...e/F16_231p.rar
chersasha1 вне форума   Ответить с цитированием
Старый 12.07.2010, 12:44   #14
chersasha1
Вот ребята текстовый файл для работы шарика на VIP-пакет:
[CS Information]
sssp=
baudrate: 115200
filtermode: auto
filterindex: 0
slot0 =
ip: ххх.хх.ххх.хх
user: ххххххх
password: хххххххх
protocol: newcamd525
deskey: 01 02 03 04 05 06 07 08 09 10 11 12 13 14
filtermode: auto
filterindex: 0
port: ххххх
timeout: 5
slot1 =
ip: ххх.хх.ххх.хх
user: ххххххххх
password: хххххххх
filtermode: auto
filterindex: 0
port: ххххх
timeout: 5
slot2 =
ip: ххх.хх.ххх.хх
user: ххххххх
password: ххххххх
filtermode: auto
filterindex: 0
port: ххххх
timeout: 5
slot3 =
ip: ххх.хх.ххх.хх
user: ххххххх
password: ххххххх
filtermode: auto
filterindex: 0
port: ххххх
timeout: 5
slot4 =
ip: ххх.хх.ххх.хх
user: ххххххх
password: ххххххх
filtermode: auto
filterindex: 0
port: ххххх
timeout: 5
slot5 =
ip: ххх.хх.ххх.хх
user: ххххххх
password: ххххххх
filtermode: auto
filterindex: 0
port: ххххх
timeout: 5
slot6 =
ip: ххх.хх.ххх.хх
user: ххххххх
password: ххххххх
filtermode: auto
filterindex: 0
port: ххххх
timeout: 5
slot7 =
ip: ххх.хх.ххх.хх
user: ххххххх
password: ххххххх
filtermode: auto
filterindex: 0
port: ххххх
timeout: 5
slot8 =
ip: ххх.хх.ххх.хх
user: ххххххх
password: ххххххх
filtermode: auto
filterindex: 0
port: ххххх
timeout: 5
slot9 =
ip: ххх.хх.ххх.хх
user: ххххххх
password: ххххххх
filtermode: auto
filterindex: 0
port: ххххх
timeout: 5
slot10 =
ip: ххх.хх.ххх.хх
user: ххххххх
password: ххххххх
filtermode: auto
filterindex: 0
port: ххххх
timeout: 5
slot11 =
ip: ххх.хх.ххх.хх
user: ххххххх
password: ххххххх
filtermode: auto
filterindex: 0
port: ххххх
timeout: 5
slot12 =
ip: ххх.хх.ххх.хх
user: ххххххх
password: ххххххх
filtermode: auto
filterindex: 0
port: ххххх
timeout: 5
#------------CAID:PROVID-----------------------------
filter0 =
0500:030600,023700,023100,024700,024b00,042200,042 700,041700,042400,032000,032500,031b00;
4ae0:000000;
4ae1:000000;
0654:000000,000001,000002,000003,000004,000005;
090f:000000;
0652:000000,000015,0000FF;
0602:000000,000001,000002,000032,000043;
0100:000000,000068;
1702:000000;
0604:000000;
0d02:000000,0000a0;
Channel ID Table =
filter5 =
0654:000001;
0654:000003;
0654:000004;
0654:000005;
0652:000000;
0652:000004;
0652:000015;
0604:000003;
0604:000014;
0604:000066;
0604:000069;
0604:000086;
0604:000087;
Полько нужно вставить скопировать и вставить свои настройки даные шароводом, и удалить если нужно ненужный пакет и все ок.
Dr.HD F16: Двигатель Strong SRT DМ 2100: таз 1.2 на 4W-75E, 2 таза 1.2, 1й на 36Е, 2й на 80Е+85.2Е+90Е. VIP-Пакет.
Старый 17.12.2013, 18:25   #15
Clavik
Ресивер: DM800HD original
Clavik пока неопределено
Добрый день,подскажите на этого зверя мастер-код...клиент забыл
Clavik вне форума   Ответить с цитированием
Старый 17.12.2013, 18:33   #16
денис26
Ресивер: skybox f3
денис26 на пути к лучшему
Сообщение от Clavik Посмотреть сообщение
Пароль можно сбросить только одим образом - предварительно сохранив список каналов и настройки шарика потом Сделайте сброс на заводские с морды.
Вырубите сзади выключатель, нажмите на морде на кнопку Меню, и не отпуская включите рес сзади.
На синем фоне появятся 4 строки на английском
Кнопками на ресивере или пультом спуститесь на 3-ю строку и нажмите ОК.
Затем спуститесь на 4-ую строку и нажмите ОК.
Ресивер заработает.
Произойдет сброс. Заново залейте ваши старые настройки шары и каналов
денис26 вне форума   Ответить с цитированием
Старый 12.07.2010, 12:50   #17
chersasha1
SMART_Module_002p - для активации шурика
Этот модуль служит для активации эммулятора и работы шары, он заливается всего один раз.
http://drhd.legion.name/download/file.php?id=95
Старый 15.07.2010, 22:51   #18
chersasha1
- Тестируется возможность работы обменной карты 52й серии в ридере ресивера, а так же в мультикас DRE CAM добавлен режим облегченного декодирования для 5 каналов Триколора (Первый, Россия, НТВ, Спорт, Вести), по сути карта не используется при их просмотре. Режим официально включен провайдером для нерекомендованного оборудования на время акции обмена карт и продлится не вечно....
- Фикс мультикас VIA CAM для работы с Кинорейсами 1,2,3 c карт НТВ+ в ридере
- Auto resolution - теперь есть возможность отключить апскейлер ресивера, если апскейлер телека круче!!!!
- Мелкие приятные доработки
http://drhd.legion.name/drhd_f16_kor...e/F16_232p.rar
Старый 30.06.2011, 17:46   #19
alek
Ресивер: C-Tech 5000 HD Combo Plus, dreambox7020,openbox810
alek пока неопределено
По умолчанию Альтернативные прошивки для Dr.HD F16
F16_261p
Тип файла: rar F16_261p.rar 4.77 Мб 15
alek вне форума   Ответить с цитированием
Старый 25.01.2013, 23:05   #20
alek
F16_265p
Тип файла: rar F16_265p.rar 4.86 Мб 19
Текущее время: 07:44. Часовой пояс GMT +3.
