Ресивер Star Track FH 2020 HD
клон GM 990 / Amiko Alien 8900
процессор STI 7110 Feature1. MPEG-Fully DVB-S / DVB-S2 HD compliant 2. Endless channels (TV and Radio) programmable 3. Multilingual menu text support 4. Channel list editing 5. Favourite channel list editing 6. True-color On-Screen Display (OSD) 7. Full Picture In Graphic (PIG) function 8. Electronic Program Guide (EPG) for on screen channel information 9. Subtitle supported 10. Teletext supported by software emulation 11. Parental lock facility by channel and program event 12. Program and Channel information transfer from receiver to receiver 13. S/PDIF for digital audio or Dolby digital bitstream output 14. DiSEqC 1.0, 1.1, 1.2 and USALS 15. HDMI HD Video/Audio Output 16. USB 2.0 Host 17. LED Display for service information 18. RTC (Real-Time-Clock) 19. Time Shift 20. Video Recording 21. Recording one channel and Time Shifting another channel (optional) 22. Conax Embedded Card Reader 23. FullHD 1080p output via HDMI 24. AVI, MKV, MPG, TS, WMA, WMV, M2TS, FLV, DAT, ASF, MP3 playback 25. YouTube, SHOUTcast Radio, and Picasa Compatible 26. Weather forecast & Rss Reader Functions 27. Software Upgrade support via USB, RS232 or Internet 28. Endless possibilitier with Plug-In support 29. Message, FAQ and User Manual support 30. Download files from FTP server 31. Base on LINUX Specification SYSTEM RESOURCES Main Processor 450M Hz based CPU Flash Memory Nor flash:8MB X 1 ; Nand flash:512MB X 1 DDR SDRAM DDR2 128MB x 2 Tuner/Front-end(Optional) Tuner Type DVB-S / DVB-S2 Input Connector F-type, Connector, Female Loop Through F-type, Connector, Female Signal Level -65 to -25 dBm LNB Power & Polarization Vertical: +13V/+14V Horizontal: +18V/+19V Current: Max. 500mA Overload Protection 22KHz Tone Frequency: 22±1KHz DiSEqC Control Amplitude: 0.6±0.2V Version 1.0, 1.1 1.2, USALS Available Demodulation QPSK, 8PSK Input Symbol Rate 2-45 Mbps, Convolution Code Rate 1/2, 2/3, 3/4, 5/6,7/8,1/4,1/3,2/5,3/5,4/5,8/9,9/10 and Auto POWER SUPPLY Input Voltage Free Voltage (100~240V AC, 50/60Hz) Power Consumption 20W MAX MPEG TS A/V Decoding Transport Stream MPEG-2, H.264 Input Rate Max.120Mbit/s Aspect Radio 4:3, 16:9, Letter Box Video Decoding MPEG-2, MP@ML, MPEG-4 part 10/H264 Video Resolution 720*480P/I, 720*576P/I, 1280*720p,1920*1080i,1920*1080 Audio Decoding MEPG-1 layer I/II, Mpeg2 layerII, Dolby digital Audio Mode Left / Right / Stereo/ Mono Sampling Rate 32, 44.1 and 48KHz A/V & DATA INPUT/OUTPUT TV-SCART Video CVBS/RGB output Audio L/R output RCA A/V Video CVBS output Audio L/R output S/PDIF Coaxial, Digital Audio or Dolby Digital Bit Stream Output RS-232C Transfer rate 115.2Kbps 9 pin D-sub Type RJ-45 10M/100M USB One USB 2.0 slot Compatible for Host HDMI VER1.2 Type A фото http://img818.imageshack.us/img818/4004/2020hd.jpg http://imageshack.us/photo/my-images/849/2020hd.jpg/ |
имидж восстановления Startrack FH 2020 HD SPARK
http://depositfiles.com/files/k6fxavh7i |
емулятори для Startrack 2020 HD
calculate CCcam214 mgcamd.sh4 oscam-1.10rc-svn-sh4-linux plugin_e2upgrade.s plugin_mcas_v1.4.s plugin_update2remote spcs скачать отсюда http://depositfiles.com/files/uimumlpmm |
по скольку ресивер клон GM 990 / Amiko Alien 8900
то выкладываю Enigma2 от PKT gm 990 nebula v1 это самый стабильный из всех сборок энигма для 2020 HD пробовал наверное все сборки от AR PKT EOS ........ это самый лучший пульт работает все работает, только не знаю почему сигнал ниже на 10% от sparka и не работают несколко каналов на 36e НТВ+ виасат ехплорер, хисторы если кто нибудь знает как лечить буду признателен за помош скачать отсюда Enigma2 for Startrack FH 2020 HD http://depositfiles.com/files/dtv81kt3a |
Большая просьба выложить свежую прошивку Spark под StarTrack FH2020 HD. Восстановил образом, но Spark online не работает, стандартная прошивка Amiko 8900 c офф сайта не ставиться.
kak proshit star track 2020 hd plus.
Люди у кого есть прошивки на это чудо, на обммениках выложил довно а уроды удалили а сейчас не счем восстанавливать прошивку :(
Не знаю откудо скачать :(
Скрывайте под HIDE |
| Текущее время: 18:51. Часовой пояс GMT +3. |
