Обсуждение OPENBOX S10 HD
Краткий обзор ресивера Openbox S10 HD PVR
http://imgdepo.ru/out.php/i61841_openboxs10minimain.jpg работает со всеми провайдерами по шуре. li3602 Протокол: CCAMD, NEWCAMD, MGCAMD PEG1/2/4, H264, AC3 080i+CA+C Openbox S10 hd dvb-s2 receiver HD Specification: *Receive Digital High Definition (HD) and Standard Definition (SD) Satellite Signal *Supports DVB-S, DVB-S2, MPEG-2 & MPEG-4 *Digital Video Recorder through USB (external flash or hard drive not included) *Worldwide compatible *Hardware Blind Search DVB-S and DVB-S2 *Multilingual support on screen menu (OSD): English, French, German,Italian, Russian, Spanish, Portuguese, Turkish,Polish, Arabic, Persian,and so on *400 MHz MIPS Processor - ALi OS *Fully compliant MPEG-4 H.264/AVC Main Profile Level 3 & High Profile Level 4.1; *Fully compliant MPEG-2 MP HL & MP ML; *Fully compliant MPEG-1 Layer I & II & III, *Dolby Digital Audio(AC3) *SCPC & MCPC receivable from C/Ku band satellites *Multiple LNB-Switching control (supports DiSEqC1.0/1.1/unicable) *Motor Support: DiSEqC 1.2/1.3 (USALS - GoTo X) *HDMI 1.3 output *PVR (store on USB external disk) *Multimedia files playback (by USB); *7 Days Electronic Program Guide (EPG) *Teletext and subtitle out through OSD *Multi-lingual DVB subtitle and teletext *Automatic and Manual Channel Scan, Automatic Service Scan *NIT search, Hardware BLIND SEARCH *Fast channel switching < 1 second *OSD in many languages and skin-support *Multilingual support on screen menu (OSD) *Multiple display mode: 1080i/720p/570p/576i/480p; *Videotext Decoder *Analog RCA audio output: stereo (L+R); *Digital audio output: S/PDIF by coaxial *S/PDIF Interface for digital bit stream out (AC-3) *YCbCr Component Video Output *1 x Scart (RGB, FBAS or S-Video) *Screen format: Auto, 4:3, and 16:9; *Upgrade software through USB2.0 port *Powerful user interface program management function, parent lock *1x CI built-in *1x CA (smartcard reader) built-in *10/100Mbit Ethernet Interface *US or Europe Power Cord (please specify when ordering) DVB-S2 Input Frequency:950~2150MHz Loop Out Frequency:950~2150MHz Input Level:-65~-25dBm Input Impedance:75 LNB Power: Auto/14v/18v/OFF, Imax = 500mA Video decoder Video Compression MPEG-2 and MPEG-1 compatible, H.246 Video Formats 4:3 / 16:9 Letterbox for 4:3 TV-Device Audio decoder Audio Compression MPEG-1 & MPEG-2 Layer I and II, MP3 Audio Mode Dual (main/sub), Stereo Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz Output digital Output Level 0,5 Vss on 75 Ohm Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz S/PDIF-Output optical, Toslink Video parameter Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm Teletext filter in conformity with ETS 300 472 Standard TV-Scart Output: FBAS, RGB, S-Video Serielle Interface RS 232 Typ RS232 bidirectional Bit rate 115,2 kBit/s max. Plug Connector SUB-D-9 Ethernet 10/100 MBit compatible interface USB 1 x USB 2.0 Host ,PVR LNB power and polarisation per tuner LNB Current 500mA max.; short-circuit-protected LNB Voltage vertical < 14V no load, > 11,5V at 400mA LNB Voltage horizontal < 20V no load, > 17.3V at 400mA Count of active satellite position DiSEqC 1.0/1.1/unicable/1.2 SAT POSITION / SAT OPTION DiSEqC - Rotor Control External PSU Input:110-240V AC / 50-60Hz / 0.6A Output: 12V = / 3,0A Physical specification Ambient Temperature +15∑C ~ +35∑C Humidity < 80% Size (W x D x H): 300 mm x 220 mm x 56 mm Weight: 1,8 kg?without HDD Power AC input range:100-240VAC 50/60Hz PowerConsumption (Standby): Max. 10W (<1W http://imgdepo.ru/out.php/i61842_4E954DBD1F0E.jpg http://imgdepo.ru/out.php/i61845_EF8F4DBD1F0E.jpg http://imgdepo.ru/out.php/i61847_1BA04DBD1F0E.jpg http://imgdepo.ru/out.php/i61848_12AC4DBD1E7C.jpg http://imgdepo.ru/out.php/i61849_65124DBD1E7C.jpg http://imgdepo.ru/out.php/i61851_back.JPG http://imgdepo.ru/out.php/i61852_inside1.JPG http://imgdepo.ru/out.php/i61853_inside2.JPG http://imgdepo.ru/out.php/i61854_screen1.JPG http://imgdepo.ru/out.php/i61855_screen2.JPG http://imgdepo.ru/out.php/i61857_screen6.JPG |
По внешнему виду и меню ну уж очень похож на Globo
http://s1.ipicture.ru/uploads/201108...s/3v2b0K5E.jpg |
Никто не в курсе до какой скорости разгоняется лан в этой модели? Юзаюсь пока на CI-7200PVR, так у него едва до 40Mb/s дотягивает. Тормоз редкосный. |
Китайский сенденпал!!
надо в в первом посте написать что это китайская поделка косящая под Опенбокс.
и соответственно и качество и гарантия соответствующие... Опены копируют для не щарящих многие модели. а потом тупые клиенты которые были разведены "умными" установщиками кричат что опены дерьмо... |
Вложений: 1
OpenBox S9/S10 Firmware Tool 0.4 by MST
This tool allows you to: - analyze Openbox S9/S10 firmware file (*.abs) - extract channel list to TP_PROG.dbs file (so you can extract list from .abs edited with SetEditHD100 tool) - preview, extract and replace background logo file (Back_logo.m2v) - preview, extract and replace boot logo file (Boot_logo.m2v) (preview is not working for firmwares with non pure m2v format boot logo) - check block's CRC and fix it - extract and replace whole blocks and blocks's data only Things that tool cannot do, but maybe be able to do in future: - decrypt maincode, for example to get firmware release date - preview boot logo for some firmwares with non pure m2v format Цитата:
не разархивируется
Идёт Openbox S 10, как мне его настроить на шаринг? Я чайник в этом деле. Пишут оригинал.
Як правильно прописати ключі на БІСС Інтер та Інтер+?
Openbox S10 Китай |
Текущее время: 13:45. Часовой пояс GMT +3. |
