Форум VolSat
-   Enigma 2 (http://forum.volsat.com.ua/forumdisplay.php?f=340)
-   -   Имиджи от Eos Developer Team (http://forum.volsat.com.ua/showthread.php?t=3951)
Admin 07.06.2011 12:25
Eos Developer Team - домашня сторінка http://www.sat-ulc.eu. Іміджі збираються для приймачів Edision argus pingulux . На рахунку у команди 3 іміджі. З відмінностей від інших іміджів робота картоприймача. Робота з ему базується на додатку ACT Emumanager.
olegnik 08.07.2011 09:17
учить немецкий? )
и где там имиджи искать под алиен?
svan 02.11.2011 03:18
"под алиен", похоже, не делают
ivan1975 12.01.2012 15:24
ставится нормольно на Amiko
ivan1975 12.02.2012 11:44
NeuProLux v2 Amiko Alien
What's new:
Everything from the v1 course PLUS:
new WikiLux
External Card Reader work
3x OverClocking: boat, image, standby
RC1 lirc support, RC2, GM; RC1/2/GM selectable as a single RC
Car IPKGInstaller at (/ tmp) simply ipkg, tar.gz in and ready
Manual Install of further subsequent versions
(It does not matter what drive you have and is much faster than the original install process)
New Emupaare Vizecam Camd3 + and + oscam camd3 for Orf by emu and everything else the same CS
Boat video set (depending on volume level and display individually)
Stick Swap
Auto Standby timer
(Xx hours after the box goes into STBY or DeepSTBY
it is taken the last keystroke, the FB!)
Neutrino / Spark entry in the menu set PowerOff
Summer time / winter time adjustable
EPG Auto Save
Uptake from deep standby possible
Find Service by letter
and much much more ....
ALL NAT. RIGHT WITH DEEP STAND
0.6 watts
Current station list
New Keys:
Find button (magnifying glass) = Find Service
White button = ScreenShot by FB
Optimizations:
Optimized backup
(2 min wait. Less)
Automount on startup
(HDD's and Stick's are correctly identified and mounted)
Display ON / OFF (in Stby) [F1 + Blue]
Display ON / OFF (DeepStby) [Blue]
In addition:
Camd3 update in Emumanager
Experimental:
NF-PN plugin
NF-RSS plugin
Still includes:
HD-Skins
cifs - integrated network shares (Windows shares, etc.)
Spark reboot (you can keep your back straight from the E2 to boot original firmware!)
Start neutrino (so you can switch to NeutroLux)
E format (so you can delete the E2 completely from your Pingulux. Very good case for the service!)
Backup (to create a complete. Backup of your images)
Standby time
Teletext (SAT button)
Web interface with full remote control adjustment (except FAV button)
PowerOff Menu
EmuPack
... and much more!
If after a triple boot loop NeuProLux be started, the boat started without video.
Known BUG's:
Network Wizard
When setting the IP and DNS config on the first run "Network not available" message.
Solution: Just set everything again and again!
TV / Radio Mode
When you open the last channel is displayed, but not the same play.
Solution: First of all choose a different channel and switch back.
When two images:
SCART users will not see the boat video. http://www.mediafire.com/?mqsc5lw014hhxel
vampirex 12.02.2012 13:39
Этому имиджу уже пятый месяц пошёл...Обрадовался уже , что новый вышел!
http://www.sparkfans.net/viewtopic.php?f=73&t=938
ivan1975 12.02.2012 13:51
Сообщение от vampirex (Сообщение 110348)
за что купил за то и продал http://sat-planet.net/showthread.php...838#post204838
ivan1975 27.06.2012 23:02
Новая версия имиджа от команды NF-EOS-Dev-Team
http://3.firepic.org/3/images/2012-0...a1b7pgxd6g.gif
ProtoLux V4
Doraty236 03.07.2012 22:28
Сообщение от ivan1975 (Сообщение 124883)
ProtoLux V4
кто нибуть его уже ставил?
SLAVIK S 04.07.2012 06:09
Сообщение от Doraty236 (Сообщение 125419)
Ничем не отличается от предыдущей версии.
svc75 04.07.2012 22:41
А у меня не пошел. 2 раза ставил - и результата нулевой, ставиться, пишет успешно, перезагрузка и черный экран.
SLAVIK S 05.07.2012 07:04
Сообщение от svc75 (Сообщение 125506)
После установки надо тумблером сзади перезагрузить.
svc75 05.07.2012 13:35
Сообщение от SLAVIK S (Сообщение 125535)
Раз 5 выключал, включал. Результат нулевой.
Текущее время: 16:16. Часовой пояс GMT +3.
