ACamd
Вложений: 1
ACamd_0603
10.04.2009 V 0.6.0.3 NDS - Fixed Multi package EMM's - Fixed lot off small and some big things |
Acamd 06.1.0
Вложений: 1
Acamd 06.1.0
- Info When starting with new version off ACamd first delete ACamd.ini... - Added CCcam native client [cccamn] beta with EMM support - Added Beta tunneling B: line, ECM and EMM, for cardreader to - Added Multiple EMM's for Seca updates - Added PAT, CAT and PMT load after channel sellect. - Added option [Disable Key Delay (set it to 0)] default ON - Changed Type error [Disable Client on Bad Connection] (and ini change) - Changed DisableClientOnBadConnection changed default to OFF - Changed DVBViewerStartupDelay from 1500 to 100 - Delete A: line (replaced with B: line) - Delete Option [Newcamd disable check on ProviderId] - Delete Ini Option Newcat - Delete cache.ini |
Вложений: 1
Acamd 0.6.2.0
- Added Anysee support - Added FTDI support (smargo) - Added SoftCsa mode - Changed When disable PMT or CAT scan, disable cache scan to - Fixed PMT, missing some HD entries - Fixed lot of small issues, CCcamN, EMM - Removed Emubox03, GBoxN, MBoxN - Same MDAPIFilter.ax v0.0.0.6 - Update ACamdMonitor.exe v0.0.0.3 |
Вложений: 1
ACamd-Editor-V2.0
Текущее время: 20:48. Часовой пояс GMT +3. |
